Nextbook 8 (NX785QC8G) Official Firmware Update Is Out
So far trying to burn this battery out. Lol having difficulties. But that means this tablet is worth the $100. Great tablet this is. Sure there are reboots but due to the battery fix this tablet lasts very long. Started at 6:00 and for 12 hrs. Its at 54%. Loving this more now. Calibrated it at 100% at proper proper level and this tablet runs like clockwork.
Originally posted by mel4787 View PostSo far trying to burn this battery out. Lol having difficulties. But that means this tablet is worth the $100. Great tablet this is. Sure there are reboots but due to the battery fix this tablet lasts very long. Started at 6:00 and for 12 hrs. Its at 54%. Loving this more now. Calibrated it at 100% at proper proper level and this tablet runs like clockwork.
ShaunMTFreaktab Rom Developer
Originally posted by mel4787 View PostWhat I did was unplug the part that plugs into the board. Replug it in securely and make sure it is plugged in firmly. Also there is a gap where the wires are. You will see it.. You have to put something in that gap so that it doesn't move at all.Freaktab Rom Developer
Originally posted by mel4787 View PostWhat I did was unplug the part that plugs into the board. Replug it in securely and make sure it is plugged in firmly. Also there is a gap where the wires are. You will see it.. You have to put something in that gap so that it doesn't move at all.Originally posted by shaunmt View Post^ What he said ^
Originally posted by mel4787 View Postso how is twrp coming along? along with a custom rom
I have successfully compiled a full OmniRom build, but I haven't even attempted to test it because I haven't yet tweaked it to support our various hardware components (lcd screen, touch digitizer, GPU, WiFi, Rotation Sensor, etc...). I'll work on it more after I get TWRP installs working.
Assuming I get OmniRom working, I'll switch the codebase to CyanogenMod and try it next.
Originally posted by mel4787 View Postthats great that the rom is built. hmmthe update.zip is used for what exactly? and also when omnirom is formatted to our devices thatll be all we need since we really dont use an update.zip to flash a rom.
TWRP doesn't support the rkimage update.img format and I don't want to provide user support for the various PC rockchip flashing tools.
I was going to port the rkimage update.img flashing feature from the stock rockchip source code, but it doesn't work correctly even in the stock ROM and it's not worth the time to fix it. Getting the TWRP update.zip format to work will be easier and provide greater flexibility in what we are able to install.
There are currently 2387 users online. 0 members and 2387 guests.
