Linux XBMC for square box (beta) - Gotham 13.1
    AMLinux Gotham 13.2 for ENY EM8 is ready.
    Download it from http://www.stane1983.com/amlinux/
    More info on same page.
    Install via Update application in android or from recovery menu by selecting downloaded zip.
    BE NOTED: This Linux firmware is for EM8 box ONLY. It will upgrade bootloader on box.
    Cheers,
    Stane1983
    If you find my work useful, buy me a beer
    Homepage: http://www.stane1983.com
    Originally posted by stane1983 View Post
    I made M8 Linux XBMC build for EM8 box (with AP6330 wifi, not sure if there are boxes with other wifi, in worst case wifi will not work for you).
    Bugs:
    • Bootlogo and splashscreens (booting up/shutting down) are not shown
    • 720p and 1080i/1080p resolutions work for sure, however I'm pretty sure 4k output will not work at all or will not work correctly
    • When network connected via cable MAC address is picked randomly so on each reboot box will have different MAC address and IP address assigned by router. This means that router's DHCP pool might fill up quickly if there are many reboots.
    • for you to tell
    Download: Link
    BE NOTED: This Linux firmware is for EM8 box ONLY. It will upgrade bootloader on box so it will output default resolution on HDMI 720p instead of 1080p
    Cheers,
    Stane1983
    Thanks for the great work, couple of questions:
    1- Does the bootloader allow to boot into Android with a menu option or does the box lose Android O/S?
    I really need certain Android apps.
    2- Will there be a version with 1080p boot in future like Finless recent ROMs?
    Thanks again
      Bugs:
      • for you to tell
      Download: Link
      Cheers,
      Stane1983
      Cheers mate just testing now
      Bugs are Sons of Glitches!
      JustMe
        Thanks again
        Hi, it's NAND install like MX linux, means Android is gone. I changed to 720p initial output because some users have older TVs which don't support 1080p. Resolution to 1080p can be changed in xbmc.
          all good here
          i also now notice there is more ram available before it used be 900 to 1100MB now I have 1435 mb free
          cpu 0 = 2.1%
          cpu 1 = 1.2%
          cpu 2 = ?
          cpu 3 = ?
          1920x 1080p 28 to 60fps
          memory usuage 6%
          all in idle mode
          xbmc 13.1 compiled Jul 9th
          operating system Linux 3.10.47
          switch xbmc off and unit switched off , then use remote to switch back on
          40sec to boot into xbmc
          oh yeah heap snapier to navigate
          Can confirm bug power on logo and switching off randomly show upor screwed up
          Dobro Falla
          JustMe
          JustMe
            Hi, thanks. If this is installed, can it be reverted back to Android via recovery? Cheers.
              Yup, just put android firmware on sdcard and boot into recovery with recovery button pressed.
                Thanks. Might have to buy another box, one for each system.
                  be nice if there was liek ookla speed test in xbmc which i use some time to see if there issues with the net when movies are playing slow
                  JustMe
                  JustMe
                    will there ever be 12.3 version stanes
                    JustMe
                      - Bug I lose usb mouse I cannot get it to work it just disappears and have to unplug and plug back in
                      - Bug also in wifi manager does not show the ssid to connect to
                      JustMe
                      JustMe
                        Re: Linux XBMC for square box (beta) - Gotham 13.1
                        JustMe
                        Run speedtest-cli in ssh console
                          Frodo? No, porting all m8 changes back to grodo... Too much work
                            JustMe
                            Might be kernel bug, will try to compile with more recent kernel src tree
                              ok thank also
                              JustMe
                              JustMe
