Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by pigbait View PostI would also like to know the FTP password and username.
Originally posted by pigbait View PostTried sftp with winscp and no dice maybe wrong port?
Will change to sftp in next fw, i recall I always had some issues with proftpd on buildroot linux.
Some answers
@JustMe
- Bug I lose usb mouse I cannot get it to work it just disappears and have to unplug and plug back in
Will check that, I'm using also 2.4G airfly mouse + keyboard and did not notice that issue
- Bug also in wifi manager does not show the ssid to connect to
which wifi module used in box? Which router? More info... On my box it works.
- very slow network allot of buffering via lan network side need tweaking also i think
Wifi or lan? I can't do hard tests on that but speedtest showed me 9.58Mbit/s download which is ok for my 10Mbit download speed max (Internet)
over wifi
@Marton4
- Question: does the installed XBMC have AMLogic hardware support?
Yes, video is HW accelerated
@madweegie
- Does the linux xbmc auto switch resolution for movies on android hardware ? like 24hz etc etc
I think not and can't test it because my TV doesn't support 24hz. Anyway, if it does, in settings you
should be able to switch to 24hz.
Cheers,
Stane1983
Great Start
over wifi
@Marton4
@madweegie
Cheers,
Stane1983
This is a great initiative. I tested the build today and found a lot to like. Well done, you
Ethernet performance falls behind the rest: some significant buffering on my 100 mbps link. Altogether more than with Lifeforce or Finless Android. Fix that, add a splash screen with your sig and we're away!
over wifi
Cheers,
Stane1983
Stane,
The chipset is AP6330 module and the router is a netgear d6300
slow speed is lan , I cannot test wifi as my wifi manager show no ssid for me to connect too.
also what is the ftp credentials?
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by TMx View PostFTV is broken 13.1 issue... Mashup links has some server issues at the moment ...Navi-X Ok here...
JustMe
speed test on console
SD : 231.345 ms
Testing download speed........................................
Download: 10.30 Mbit/s
Testing upload speed............................................. .....
Upload: 0.79 Mbit/s
around 2.5 to 3Mbit/s to US Servers
JustMe
Originally posted by stane1983 View PostPersonally, I'm having headache when I have to develop any kind of firmware for devices from EM8 manufacturer (m3, mx2...). I'll build it after linux for s82, but I cant promise it will work fluent...
It gave me headaches!
Re: Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by Finless View PostI agree completely! I almost gave up doing any work on this box!
Originally posted by pigbait View PostWell you linux build is quite nice.. not sure how different this is from an Android kernel... but please don't give up on these boxes....
User here claims that his box does have Broadcom ap6330 wifi module and it doesn't work... My box have same wifi module and it works...
I'm not giving up, just complaining
Originally posted by stane1983 View Postfactory is just making a mess... Similar issues with mx2 box.
ENY contacted me several times but never followed up! I don't think they care.
This hardware is a mess and I agree....
There are currently 3887 users online. 0 members and 3887 guests.
