Linux XBMC for square box (beta) - Gotham 13.1
Hi stane, really enjoying your xbmc linux build but one little annoyance is it doesn't have the exact same IR remote layout compared to android. The stock remote works fine but as you probably know the eny m8 share the same IR instructions as the G-Box Midnight MX2. So I can use that remote extra buttons (play/pause, fwd, rwd etc.) with the m8 on android. Is this possible to implement the same layout on your Linux build?
Thanks, I appreciate your work.
Originally posted by Iru786 View PostHi,
Can someone please advise how do i open ssh console to do a speed test?
Originally posted by Night_Hawk View PostYou can google putty ssh client and download it to you pc. No need to install it just run the .exe file from a pc and enter the ip address of your M8 box in the ip address / hostname field, leave the port as 22 and the connection type as SSH, click open, accept the sshkey prompt and enter the username root and letmein as the password. Once the session is open type speedtest-cli and press enter. To close the ssh session just type exit.
Re: Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by lowsum View PostHi stane, really enjoying your xbmc linux build but one little annoyance is it doesn't have the exact same IR remote layout compared to android. The stock remote works fine but as you probably know the eny m8 share the same IR instructions as the G-Box Midnight MX2. So I can use that remote extra buttons (play/pause, fwd, rwd etc.) with the m8 on android. Is this possible to implement the same layout on your Linux build?
Originally posted by stane1983 View PostBoth versions (Square box and S82) will get update this weekend or beginning of next week )
Also , did you get the new MX3 Box 1gb version yet?? Are you planning to release a linux build for that box as well any time soon ???
There are currently 3377 users online. 2 members and 3375 guests.
