Linux XBMC for square box (beta) - Gotham 13.1
Have you seen this? http://www.theaterinabox.tv/tv-boxes...ure-linux.html
I wonder what firmware and skin these guys are running. Check the YouTube clip.
Originally posted by handroid View PostHave you seen this? http://www.theaterinabox.tv/tv-boxes...ure-linux.html
Linux (buildroot), same as mine. About skin I don't know, I'm not author
Re: Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by stane1983 View PostHi,
I made M8 Linux XBMC build for EM8 box (with AP6330 wifi, not sure if there are boxes with other wifi, in worst case wifi will not work for you).
Bugs:- Bootlogo and splashscreens (booting up/shutting down) are not shown
- 720p and 1080i/1080p resolutions work for sure, however I'm pretty sure 4k output will not work at all or will not work correctly
- When network connected via cable MAC address is picked randomly so on each reboot box will have different MAC address and IP address assigned by router. This means that router's DHCP pool might fill up quickly if there are many reboots.
- for you to tell
Install via Update application in android or from recovery menu by selecting downloaded zip.
BE NOTED: This Linux firmware is for EM8 box ONLY. It will upgrade bootloader on box so it will output default resolution on HDMI 720p instead of 1080p
Cheers,
Stane1983
Sent from my Minix Neo X8-H using Tapatalk.
There are currently 2426 users online. 0 members and 2426 guests.
