@pigbait, clear-headed reply, thanks.
Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by al8782 View PostMy stock remote isn't working. Can't adjust volume or even turn the box off.
My wireless keyboard works, accept for volume down.
I had the same thing happen when I installed the one on his website which I dont think I should have since it is apparently for other model boxes.
Originally posted by borikua View PostDid you install the file from this thread post 1 or did you install the one located on Stanes website?
Did you install the one from this thread right over top of the one from his site. Or did you have to reinstall the original android firmware first and then the build from page 1.
ThanksLast edited by al8782; 11 September 2014, 13:38.
I installed the build from page one.
Cant connect to wifi - no access points show up to choose. When I load my Mx2 boxes and don't install the original Android firmware like 1.1.5 or 1.1.6 before I install a linux build I get no access points also.
But with this box I wiped cache, clear data/ factory reset, rebooted and install this build but over to of Stanes other linux. What I need is the M8's original firmware so I can reinstall that and then install the linux build from this thread.
Does anyone know where to get the M8's original firmware?
Originally posted by al8782 View PostOk went back to original Android build for M8 and installed the linux build here. Still no access points to choose from to connect to wifi.
Is this a known bug?
Originally posted by nukeybrown View Postthat at means it's not an official em8 tomato box, it has a different wifi chip etc inside which has no linux build as yet.
I see what you're saying about the wifi. Reread what Stane said about the wifi chip.Last edited by al8782; 12 September 2014, 00:30.
Originally posted by pigbait View Postfrom my understanding stane is waiting on more kernel release, I'm sure he hasn't forgot about us... we just all need to be patient my self includedI'm testing linux and android firmwares for m8 boxes. Don't want to release semi-working fw.
For now:
- Latest Amlogic armhf compiled kernel with armhf compiled buildroot and xbmc
- Initial tests are good, performance increased 30% or even more
- Still have to patch minor things in video playback (video goes out of screen).
Originally posted by stane1983 View PostI did not forget you guysI'm testing linux and android firmwares for m8 boxes. Don't want to release semi-working fw.
For now:
Looks like I bought the wrong square M8 box. Can you tell me the box and model number so I can purchase the right one.
Originally posted by al8782 View PostLooks like I bought the wrong square M8 box. Can you tell me the box and model number so I can purchase the right one.
For now:
There are currently 2580 users online. 1 members and 2579 guests.
