Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by stane1983 View PostNo, it means MXIII 1Gb I will receive from another source week or 2 later
While it is off topic are you going to compile an Android version for 1GB too?
Keep up the good work, I wish you the best!
Hi every one i have been using this now for a while and i love it i hated my M8 as you know lol but now i love it all thanks to stane he honestly deserves many thanks for his work.
I forgot to ask dose this play 4K stane as i hope to get a 4k tv soon just wondering.
I am looking forward to the new version but i am happy with what you gave us now to.
Originally posted by ozychris View PostHi every one i have been using this now for a while and i love it i hated my M8 as you know lol but now i love it all thanks to stane he honestly deserves many thanks for his work.
Kodi's, The new name for XBMC, 14.0 version(aka Helix) will support 4K and the AMLogic 802s chip.
Gotham(xbmc 13.2) is the last stable version, so not official support yet.
I've been using the Mx2 for almost a year now and have messed around with many different linux builds for that system. Most probably know with the Mx2, that certain linux builds need to be installed over firmware 1.1.5 or 1.1.6.
With this linux build does there need to be a certain firmware installed on lets say a M8 Amlogic Quad Core?
I just received my M8 today and want to make sure I install this linux build over the right firmware.
Originally posted by al8782 View PostI've been using the Mx2 for almost a year now and have messed around with many different linux builds for that system. Most probably know with the Mx2, that certain linux builds need to be installed over firmware 1.1.5 or 1.1.6.
Originally posted by snelsy View PostI just went into recovery and installed from zip on sd card it removes android,personally i would wait though until the new build is out it is due anytime now.It doesn't matter which firmware you have.
I know on the Mx2 you can't install a difference linux build over top another linux build. You need to reinstall the right firmware for that, either 1.1.5 or 1.1.6.
So I'm use it's the same for the boxes with Amlogic s802's.
I've got the mx2 running openelec which i'm keeping now with the codesnake version it's very good imo,i also have an m8 box which you can just restore to factory settings if you don't like linux.My box is a square m8 box i bought from acemax.I an running stane's linux version and that is better than any android version of xbmc i have tried.
Originally posted by snelsy View PostI've got the mx2 running openelec which i'm keeping now with the codesnake version it's very good imo,i also have an m8 box which you can just restore to factory settings if you don't like linux.My box is a square m8 box i bought from acemax.I an running stane's linux version and that is better than any android version of xbmc i have tried.
My question is, say you want to install a different Linus build on your M8. Now I'm not sure but wouldn't you have to go back to the original android build before you flash a new linux build, same way as on the Mx2.
What I'm trying to find out is where would be able to get the original firmware for the M8, incase I have to install it again to switch linux builds.
i used to get my firmware from acemax but the link has been down for a couple of weeks now http://www.acemax.net.cn/en/shownews.asp?id=126,this thread may help you http://www.freaktab.com/showthread.p...ht=m8+firmware
Originally posted by snelsy View Posti used to get my firmware from acemax but the link has been down for a couple of weeks now http://www.acemax.net.cn/en/shownews.asp?id=126,this thread may help you http://www.freaktab.com/showthread.p...ht=m8+firmware
Re: Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by Zahir View PostAny word (real) on Stane's next AmLinux release for the M8?
By comparison, the rest of this thread is just a pleasant fireside chat...
There are currently 1803 users online. 0 members and 1803 guests.
