Linux XBMC for square box (beta) - Gotham 13.1
Re: Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by stane1983 View PostGuys, Amlogic finally released armhf libraries. Stay tuned, update will be asap...
Originally posted by tampametal View PostGoing to boot into xbmc linux version no extra anything.
But by all signs of first version this should run insanely good.
Sent from my Minix Neo X8-H using Tapatalk.
Originally posted by stane1983 View PostWho said anything about android libs?Amlogic released their buildroot (I'm not using their) with armhf linux framebuffer libs included which I'm going to use.
RK3288 Devices
- Overview BOX (LINK !)
Installed and currently being tested.
Originally posted by stane1983 View PostHi,
I made M8 Linux XBMC build for EM8 box (with AP6330 wifi, not sure if there are boxes with other wifi, in worst case wifi will not work for you).
Bugs:- Bootlogo and splashscreens (booting up/shutting down) are not shown
- 720p and 1080i/1080p resolutions work for sure, however I'm pretty sure 4k output will not work at all or will not work correctly
- When network connected via cable MAC address is picked randomly so on each reboot box will have different MAC address and IP address assigned by router. This means that router's DHCP pool might fill up quickly if there are many reboots.
- for you to tell
Install via Update application in android or from recovery menu by selecting downloaded zip.
BE NOTED: This Linux firmware is for EM8 box ONLY. It will upgrade bootloader on box so it will output default resolution on HDMI 720p instead of 1080p
Cheers,
Stane1983
Just a little bit of Polishing, splash screen and it's good to go.
Wifi with a Tp-link router works great.
Time synchronisation only issue I encountered.
James
Originally posted by polys View PostAnyone?
Edit /etc/network/interfaces
If you are using a cable just change:
iface eth0 inet dhcp
To:
iface eth0 inet static
If you want to use your wifi add this line at the end of the file:
iface wlan0 inet static
Under the interface you choose to use enter this:
address 192.168.2.200
network 192.168.2.0
netmask 255.255.255.0
broadcast 192.168.2.255
gateway 192.168.2.1
Of course this is the setup i copied from my interface file so you should change it according to your network.
Next edit /etc/resolv.conf
and add this text to it:
nameserver 192.168.2.1
Again i added my router you need to change it according to your network.
The problem with the DNS settings is that it won't hold a reboot.
Usually you have a skeleton for the resolve file but there is none in this build and creating one didn't helped me.
What i did was to add this line to /etc/init.d/xbmc:
echo -e "nameserver 192.168.2.1\n nameserver 8.8.8.8" > /etc/resolv.conf
Now when the xbmc script runs when the box boots it writes the nameservers to the file.
You will need to do it over again if you choose to reinstall this custom OS.
Enjoy.
To:
network 192.168.2.0
gateway 192.168.2.1
Enjoy.Will try it sometime today
Stane1983
This box is a disaster as numerous buyers online, not ****ers, prove. Even if not a clone. I gave up on android, running your Linux v1. Don't know whether to buy another proper quad core box or wait a few months for Octa Core box releases which are not expensive and have good reviews from actual users, not sellers. My only hope in the meantime is your next release. Please if you need more days after getting the recent library files, take your time. I can wait another few days or a week for you to save this box from the grave. Thanks
There are currently 2230 users online. 1 members and 2229 guests.
