Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by ozychris View Posthi all just installed this and not sure what xbmc to install yep im new thort only way to lorn is to jump into the deep end and swim or sink.
so you have installed it and your not sure what xbmc to install
JustMeBugs are Sons of Glitches!
JustMe
Re: Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by pigbait View PostIf you flashed the zip file in this thread you have installed XBMC. There is nothing else for you to do.. other then setting up xbmc the way you like it...
Originally posted by ozychris View Postpigbait thank you for the replie i didn't see xbmc in the aps i will try to install again thanks .
Originally posted by pigbait View PostYou are aware this is a Linux build for EM8 boxes right? If you install this you will no longer have android on your box. It will be XBMC only
Hi i just wanted to thank stane for this download great job mate and i can now use my M8 and enjoy it finally.
1080 movies stream smoothly no buffering picture and sound quality are great also.
GOTV series HD quality buffer a little but if you pause for a few minutes then watch its perfect to.
I connected a mouse to the unit and that also worked well.
Really happy and look farwad to your next update.
I ow you a beer
Originally posted by ozychris View PostHi i just wanted to thank stane for this download great job mate and i can now use my M8 and enjoy it finally.
I ow you a beer
Zero Cache?
Originally posted by JustMe View Postnot sure why but I get allot of buffer issues even if I do the zero cacehing where android roms and xbmc I get seldom buffering especially if I set to zero cache
driving me crazy because the stane xbmc rom perfect as I don't really use android stuff
JustMe
Originally posted by NIPSZX View PostHow do you set the cache to zero?
JsutMeBugs are Sons of Glitches!
JustMe
Originally posted by Night_Hawk View PostI have successfully managed to take a backup of my .xbmc folder on this build using WinSCP v5.17 and choosing SCP as the File Protocol then installed this version on a second box an used WinSCP to copy the addons and userdata folder to the .xbmc folder on the second box. I had to copy the advanedsettins.xml file from the .xbmc/userdata to the second box, restart the box, then copy the rest of the contents of the .xbmc/userdata to the box, then finally copy the .xbmc/addons folder to the new box, reboot and settings are the same as my other box accept the skin defaults to confluence.
Can I back up my frodo and then install it on Gotham?
Originally posted by Zahir View PostThis is a great initiative. I tested the build today and found a lot to like. Well done, you
Ethernet performance falls behind the rest: some significant buffering on my 100 mbps link. Altogether more than with Lifeforce or Finless Android. Fix that, add a splash screen with your sig and we're away!
Are you still having buffering problems on your 100 mbps link? That seems impossible. What Finless are you running?
There are currently 1829 users online. 0 members and 1829 guests.
