Linux XBMC for square box (beta) - Gotham 13.1
    Armada Mach 8 square box Linux install
    Originally posted by washere View Post
    Thanks for the great work, couple of questions:
    1- Does the bootloader allow to boot into Android with a menu option or does the box lose Android O/S?
    I really need certain Android apps.
    2- Will there be a version with 1080p boot in future like Finless recent ROMs?
    Thanks again
    when loading MX_LINUX-K200-update on my Armada Mach 8 I get MX LINUX installed successfully scrip succeeded result was
    [ upgrade_step] can not find customized_data. tar,skipping the word runs off screen i can see ing but not first part of word
    wifi working apps play video but no audio res set at 720p menu in setting freeze for couple min when trying to change settings in video or audio extra i tried setting hdmi pass though still get no audio hdmi pass though selected or not no audio and on freezing menu problem any comment would be great
      I think you might have the newer hardware.... this is a known issue with this build... you will need to wait for the next release....
        This ROM is changing the MAC address on each reboot.
        Anyway to fix this issue on my end?
        I need a ROM with a constant MAC address so my remote can connect.
          people spreading rumor that Stane has abandoned this project... I hate stupid people!
          Sent from my Minix Neo X8-H using Tapatalk.
            Rumors are not true...
            If you find my work useful, buy me a beer
            Homepage: http://www.stane1983.com
              Re: Linux XBMC for square box (beta) - Gotham 13.1
              From my understanding this is a known issue with this beta build, are you hard wired or wireless?
                Who's saying that?
                  I knew they weren't... Hey Stane, update please?
                    Originally posted by pigbait View Post
                    Who's saying that?
                    Some idiot arguing with people on twitter
                      How is the move going stane?
                        No updates I guess
                          I'm using wired but it happens on both. why?
                            Because Linux initializes and brings up network interfaces in different way than Android. I have solution for wifi mac, still working on ethernet one.
                              Thanks for chiming in @stane1983... it's nice to see your feedback.
                                Stane, any general time frame you see for release pal?
