If anyone tried to install my beta on m8n and it worked then this one will work too.
Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by al8782 View PostSame thing is happening to be like the beta release. All the addons are incompatible.
Have to try and reinstall again
Error - 'This package is for "eny_m8" devices; this is a "k200"
hi guys, been patiently waiting for this for months, i have 2 genuine Eny M8 boxes, bought straight from Eny in China
i have been running both with the older linux till today and upgraded the 1st without issue,
the 2nd one, ive tried many roms on in the past, and it seems to have a slighty different bootloader now
how can i change it back to the proper bootloader so that the new version of amlinu recognises it
Or how to i modify the amlinux to accept k200 as ok ??
@stane1983, How do i get the recovery to flash as well, I have done a tooth pick install with all 3 files from the zip onto the SD card, but once i go back to the recovery installed on my box, it is the old android one, and if i do a system wipe with the android recovery, i lose the 5gb data partition, only way back is to reinstall from SD card
thanks for this its fantastic work
Never mind I think I got itLast edited by pigbait; 27 October 2014, 05:35.
Originally posted by pigbait View Post@stane1983, How do i get the recovery to flash as well, I have done a tooth pick install with all 3 files from the zip onto the SD card, but once i go back to the recovery installed on my box, it is the old android one, and if i do a system wipe with the android recovery, i lose the 5gb data partition, only way back is to reinstall from SD card
Re: Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by htsl View PostI am having the same problem, how did you correct this issue?
There are currently 2701 users online. 0 members and 2701 guests.
