Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by stane1983 View Postuboot evironment variable ethaddr which is passed to kernel as command line argument.Bugs are Sons of Glitches!
JustMe
What's about the idea to handle it via ifconfig ?
e.g.
Code:ifconfig eth0 down ifconfig eth0 hw ether A0:15:C1:0E:24:32 ifconfig eth0 up
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostDo you also support something like init.d ?
e.g.
I've done it that way you get a message saying xbmc not same version but i go ahead and most addons and paths to movie files etc are installed.I usually have to do mashup addons again in mash settings and set up live tv again with the vdub urls i use.
I install the xbmc backup addon again and set the path to where the existing backups are.
Originally posted by stane1983 View PostYou tried to log in ssh and go to /etc/init.d folder?RK3288 Devices
Originally posted by stane1983 View PostYou tried to log in ssh and go to /etc/init.d folder?Bugs are Sons of Glitches!
JustMe
Originally posted by Daaave View PostHi there Stane
Thanks very much for all your hard work. Just a couple of problems for me..
Everything plays perfectly except .. All videos recorded on my Nexus 7 fail to play properly on the new build. Timings are out for video. Play too fast, then freeze, then play too fast etc. Codec is AVC1 (H.264/MPEG-4 AVC). Your previous build and CodeSnake's OpenElec both play these files perfectly.
Also I can't get TVHeadEnd to recognise my PCTV Triplestick 292e. Drivers for this device should be in the recent TVHeadEnd versions.
Thanks for your helpLast edited by usp; 01 November 2014, 07:43.
i have tryed a few films from a usb stick, and video slightly stutters, must admit it is very slightly, but i can see it on certain shots.
Are all you guys experiancing propper smooth playback.
update on above, and i hope someone can help.
i have just re-flashed my m8 with "justme rom" and same thing, jerky playback, after a bit of messing around with display settings, if i set it to 1080p-24hz in the main android screen, i get perfect quallity, no stutters.
is there a way i can set the default screen to 1080p-24hz using stanes xbmc linux.
****Ignore that, i have just tryed on a different tv, and it plays fine, so must have an issue / compatabilty with my samsung****
There are currently 2987 users online. 1 members and 2986 guests.
