Anyone???
Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by okey View PostCan i use the xbmc file manager to copy and paste files eg, edit advance settings.xml, or does it have to be done using putty on the linux version
Anyone???
you can't use the file manager. it's only to map folders for other xbmc features.
you need to edit the files from console.
Originally posted by okey View PostThanks for the reply, how do i edit from console ?
log into the box and use nano to edit your files. [nano-guide]
Originally posted by barnesy91 View PostYou can copy the file onto a usb drive through file manager on the box, then put the usb drive in your computer and edit the file with notepad ++, Thats probably the simplest way. Then copy the advanced settings back onto the box once edited.
Originally posted by okey View PostI have tryed using file manager, but i cant seem to find my usb within file manager, but when i go into videos/files/usb my usb files are there, but not in file manager
Go to system>Appearance>File Lists, and then tick the show hidden files and directories.
Then, Go to file manager>Add source>Browse to Root file system>Media
Then if your usb is detected there, add that as the source.
Let me know how you get on.
Silver M8 S
Stane,
Have you seen this new silver M8 S with a camera? Do you or anybody else know the differences in this box and the regular m8? Will this M8 S run your linux just as well? Also, do you have a good link for your new M8-K200 Linux? Mainly looking for some feedback on this silver box, it is a bit cheaper for some reason.
BTW: no need for more than double postsRK3288 Devices
- Overview BOX (LINK !)
at the pic
Originally posted by no_spam_for_me View Post
Originally posted by Asxetos View PostAny chance this rom (or any other) will work on 1gb-ram M8 boxes w/ AP6181 wifi?
Thanks...RK3288 Devices
Thanks...
chmod +x /etc/init.d/S60wifi
There are currently 3618 users online. 0 members and 3618 guests.
