sorry stane pronašao ovo zabavno i znaopar će pokrenuti nakon što vas za Linux
Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by pigbait View Post
sorry stane pronašao ovo zabavno i znaopar će pokrenuti nakon što vas za LinuxBugs are Sons of Glitches!
JustMe
Re: Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by JustMe View PostHere you go you indent thief’s piggy and pj8 run after stane here http://www.freaktab.com/showthread.p...566#post236566
Didn't respond to questions about whose it was for over ten days till forced
then insulted him here
now go to google transliteration and put in a line and instead of apologizing are implying he's a liar with your link meaning he has abandoned his promise?
You are not going to respect developers and programmers who build projects not steal others for very minor tinkering and are obviously enjoying insulting developers. Well like an old tree brought up bent it's too late. I hope you find some peace.
Originally posted by sukhbeer View PostI read it ...some how tried cyberduck via ssh as i have mac and putty is supported in windows only and cyberduck wont connect my M8
Sorry guys also I have noticed that my addons wont update since i have installed this ROM
Also, I noticed that all the new movies that keep on adding on Primewire/1channel since last 7-8 days also do not show up on the box
PS - I have checked that under Addon section "Auto update" is turned on as well
I am not sure why is this the case. Any here knows how to fix this issue?
Originally posted by sukhbeer View PostSorry guys also I have noticed that my addons wont update since i have installed this ROM
Originally posted by pigbait View PostXbmc was moving there server the last few days... should all be fixes now... reboot and try again.
Nothing to do with the servers as I have 2 other boxes
1. MX2 Matricom Rom
2. MX2 Openelec 4.2.1
and all the addons gets updated on the above both listed boxes, but somehow wont update on M8 Linux. I have tried to restart many times, tried restarting my router, tried turning on and off "Auto updates" but no success at all. After trying all the opitons, I am letting you guys know
Strange thing is that on Primewire/1channel not even a single movie has been added on M8 Linux box since i Installed this ROM
Please advise if there is a fix or anyone else experiencing this as well
Cheers!!
Originally posted by pigbait View PostHave you tried just going to the add-ons and hit the menu button and select update all? I know it sounds stupid but try disconnecting from WiFi on the box maybe... I've had addon freeze like that before...
Moreover i came to know there are updates for few addons (like cartoon HD, Ilive, Cliq, Genesis) because they were updated on my 2 other boxes. I even tried selecting menu on these updates and thought of updating them manually but it does not let me as the update tab is not showing/not active
Originally posted by sukhbeer View PostI am not sure if thats possible because when i select highlight "Vedio addons" and select menu I dont see update all option
In the add-ons section in system settings does it say available updates? I installed this linux rom again and every single add-on says incompatable. I'm going to have to reinstall again. This happen once before but can't remember what I did to fix it. Haven't used the box since I bought it, was waiting for the update until I started messing with it again.
Also maybe try going into file manager - program directory - database and delete the addondb folder and reboot and see if that does anything for you
There are currently 1970 users online. 0 members and 1970 guests.
