Was able to connect to WiFi and fix my clock via Night_Hawk's method but can't get my LAN connection working again. Does anyone know how?
Linux XBMC for square box (beta) - Gotham 13.1
Everything was working well for me with this ROM for a week or so until I switched my device on yesterday and noticed my LAN Cable connection was down and my clock was set to 10:00am 01 Jan 1970
Originally posted by vinpor View PostEverything was working well for me with this ROM for a week or so until I switched my device on yesterday and noticed my LAN Cable connection was down and my clock was set to 10:00am 01 Jan 1970
Originally posted by Krankie View PostS77 pro remote
http://www.****.de/itm/Best-Remote-F...-/221433283742
=> e.g. ?clone? http://www.****.de/itm/191292161825?...%3AMEBIDX%3AIT
(search for 191292161825)RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostS77 pro remote (?only available at UK?)...
Hi there
Many thanks for the Linux ROM... I just have a quick question as I have just done a fresh reinstall of the Linux ROM however, the only problem I cant fix is the that I am not able to change the date and also My time keeps stuffing up and does'nt show correct time.
Any help would be appreciated.
Also, I have seen that some people are selling M8 boxes with 13.2 Linux firmware... can some one please let me know how can I get 13.2 Linux version ROM for M8 (original PCB - samsung Memory - M8 & M9)
Re: Linux XBMC for square box (beta) - Gotham 13.1
Originally posted by stane1983 View PostHi,
I made M8 Linux XBMC build for EM8 box (with AP6330 wifi, not sure if there are boxes with other wifi, in worst case wifi will not work for you).
Bugs:- Bootlogo and splashscreens (booting up/shutting down) are not shown
- 720p and 1080i/1080p resolutions work for sure, however I'm pretty sure 4k output will not work at all or will not work correctly
- When network connected via cable MAC address is picked randomly so on each reboot box will have different MAC address and IP address assigned by router. This means that router's DHCP pool might fill up quickly if there are many reboots.
- for you to tell
Download: Link
Install via Update application in android or from recovery menu by selecting downloaded zip.
BE NOTED: This Linux firmware is for EM8 box ONLY. It will upgrade bootloader on box so it will output default resolution on HDMI 720p instead of 1080p
Cheers,
Stane1983Wholesale MX2 ,MXQ , M8 TV BOX
100% origin version
www.sunnytvtech.com
China manufacturer
aliepxress online shop
http://www.aliexpress.com/store/234219
Originally posted by luke71933 View PostHi,
Can anyone put his motherboard pic of M8 , which he successfully installed stane's linux on it. I think I have bricked mine.Wholesale MX2 ,MXQ , M8 TV BOX
100% origin version
www.sunnytvtech.com
China manufacturer
There are currently 2059 users online. 1 members and 2058 guests.
