R89-WIFI/BT/Ethernet feedback here
Been playing with the box for about 20 minutes. Can't get ethernet to connect with the internet. It shows in my router, but can't connect to the internet. The wireless connects without any problems.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostBeen playing with the box for about 20 minutes. Can't get ethernet to connect with the internet. It shows in my router, but can't connect to the internet. The wireless connects without any problems.
old android couldnt have ethernet and wlan enabled, i didnt try my ethernet yet
Originally posted by sync View Postdid you disable wireless to make ethernet work?
Off topic, but did you root your box yet?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by sync View Posti think it came rooted, i had supersu already installed
havent tried any root apps yetMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by sync View Postaww that sucks
android version 4.4.2
vendor version 106k4MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostOk, I have the same version 106k4. Still not sure why I can't get sound or ethernet working.
//edit, yeah its working, i disabled wifi to make sure but it even with wifi on it connected to ethernet, maybe i can make it a 2nd wifi router or wifi ap, awesome
it even switched the symbol in light home from the typical wifi bars to lan computer
did you try static ip?
Originally posted by sync View Postac3 is now working for me, ill plugin some cables now and see if ethernet works
did you try static ip?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
ANTUTU called this device as a MONSTER! yes it is
AP6335 Wifi Chip is amazing
5ghz wifi speed Test Download result ; 88 mbps!!! Upload ;6.5 mbps
2.4ghz wifi speed test Download result; 62mbps! Upload is 6.54mbps (thats my max U.S)
P.s UK Virginmedia Superhub 100mbps connection
Also post "ONLY" wifi/BT/Ethernet test results or problems here please....
Originally posted by TMx View PostANTUTU called this device as a MONSTER! yes it is
2.4 have maxed at Down/Up 80/6.5
5GHZ have maxed at Down/up 95/6.5
Wifi/Ethernet connected without issue.
Speedtest
What do you folks use to test your internet/wifi speed? I normally use ookla's Speedtest but PlayStore tells me it is not compatible with this device.
Paired the device with a bluetooth RocketFish mouse and I am using it - no problems to report
Also paired it with a Nexus 7 (2012 - KitKat) but I have not really tested the interfaceLast edited by 4WheelSpyder; 27 August 2014, 03:09.
There are currently 1537 users online. 0 members and 1537 guests.
