R89-WIFI/BT/Ethernet feedback here
If something is wrong at your rom (also settings/userdata/cache...), I bet OTA doesn't help, because OTA only patches a really small part of the rom...RK3288 Devices
- Overview BOX (LINK !)
Ethernet connection problem solved?
Last night I powered down the box using the on screen power button. This morning when I powered up, the Ethernet connection was not working again. I switched to wifi and got notice that an update is available. Cool, I accepted the update, it downloaded the update, but failed to install. Tried a couple of more times, then finally read the reason for the failure. "system/build.prop has unexpected content". Bingo, it dawned on me that I had changed my build prop by changing the DPI from 160 to 240. Changed it back to 160, the the update installed correctly.
After the update, my Ethernet connected again. I powered down the box using the on screen power button, and waited a few minutes before powering it up again. This time it connected to the Ethernet. Tried the same thing again, but this time I pulled the power plug and waited a couple of minutes and plugged it back in. Ethernet connected right away. Perhaps this solves the Ethernet not connecting issue.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
One thing I have noticed, the lag issue appears to have been resolved. Prior to the update, when I tried to access my Synology NAS, the connection would just sit there for about a minute or so, before it decided what to do. Now, it connects instantly and starts reading from my NAS. I think this problem, is now solved.
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by no_spam_for_me View PostIf something is wrong at your rom (also settings/userdata/cache...), I bet OTA doesn't help, because OTA only patches a really small part of the rom...
Here are the iPerf results using my PC as a server.
First is Ethernet
bin/iperf.exe -s -P 0 -i 1 -p 5001 -f k
Server listening on TCP port 5001
TCP window size: 8.00 KByte (default)
OpenSCManager failed - Access is denied. (0x5)
[264] local 192.168.1.100 port 5001 connected with 192.168.1.105 port 47283
[ ID] Interval Transfer Bandwidth
[264] 0.0- 1.0 sec 11318 KBytes 92718 Kbits/sec
[264] 1.0- 2.0 sec 11242 KBytes 92093 Kbits/sec
[264] 2.0- 3.0 sec 11413 KBytes 93494 Kbits/sec
[264] 3.0- 4.0 sec 11389 KBytes 93298 Kbits/sec
[264] 4.0- 5.0 sec 11366 KBytes 93112 Kbits/sec
[264] 5.0- 6.0 sec 11271 KBytes 92336 Kbits/sec
[264] 6.0- 7.0 sec 11262 KBytes 92255 Kbits/sec
[264] 7.0- 8.0 sec 11106 KBytes 90981 Kbits/sec
[264] 8.0- 9.0 sec 11363 KBytes 93089 Kbits/sec
[264] 9.0-10.0 sec 11293 KBytes 92510 Kbits/sec
[264] 0.0-10.0 sec 113408 KBytes 92593 Kbits/sec
Here is wifi
[272] local 192.168.1.100 port 5001 connected with 192.168.1.112 port 51910
[272] 0.0- 1.0 sec 2432 KBytes 19924 Kbits/sec
[272] 1.0- 2.0 sec 2141 KBytes 17538 Kbits/sec
[272] 2.0- 3.0 sec 2251 KBytes 18442 Kbits/sec
[272] 3.0- 4.0 sec 2424 KBytes 19855 Kbits/sec
[272] 4.0- 5.0 sec 2319 KBytes 18998 Kbits/sec
[272] 5.0- 6.0 sec 1184 KBytes 9696 Kbits/sec
[272] 6.0- 7.0 sec 843 KBytes 6904 Kbits/sec
[272] 7.0- 8.0 sec 1085 KBytes 8885 Kbits/sec
[272] 8.0- 9.0 sec 1085 KBytes 8885 Kbits/sec
[272] 9.0-10.0 sec 1069 KBytes 8758 Kbits/sec
[272] 0.0-10.3 sec 17152 KBytes 13646 Kbits/sec
Although much improved over ookla test, same tendency - starts fast, then taper off
Originally posted by 4WheelSpyder View PostCorrect, OTA did not help. Tried clearing the cache too.
First is Ethernet
Here is wifi
According wifi,I think you can test more period time,such as 60s? then see the result..Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by TMx View Postafter that small OTA update Wifi performance gone down very badly ... It was amazing but now on 2.4ghz speed gone down to average 30-35mbps from 50-60mbps , on top of that sometimes it goes really down around 6-7mbps!
Originally posted by Arbelzapf View PostI tried to connect my Apple Wireless but got a "Can't communicate" error every time.
Here is a log of me trying to pair my Apple Wireless Keyboard 3 times in a row.
This is on the latest test firmware 109k4108
logcat
dmesg
This keyboard is my only convenient way of text input and it's the first time I have problems with this keyboard on an android device, so please have a look at this issue
Originally posted by Arbelzapf View PostHere is a log of me trying to pair my Apple Wireless Keyboard 3 times in a row.
logcat
dmesg
This keyboard is my only convenient way of text input and it's the first time I have problems with this keyboard on an android device, so please have a look at this issueEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
I'm now having some significant wifi issues. Speedtest won't run when I'm on 5 ghz. I used to get 35 mbps download and 12 mbps upload. On 2.4 ghz, it runs, but speed is down quite a bit. I used to get 15 mbps download and 9 mbps upload. Now I get 6 mbps download and 9 mbps upload.
Signal levels on the R89 are weaker than the S89 now, too. On the R89, I get -77dbm on 5 ghz and -56 dbm on 2.4 ghz. On the S89, I get -58 dbm on 5ghz and -46 dbm on 2.4 ghz.
The router is a Netgear R7000. Nothing has changed with it.
I'm not sure exactly when the wifi issues began, but it seems to have been around the last couple of updates for the R89. Wifi used to be faster than the S89. I'm now on 109 firmware.
Anyone else having issues recently?
There are currently 1711 users online. 1 members and 1710 guests.
