R89-WIFI/BT/Ethernet feedback here
Originally posted by TMx View Postookla... Download it from aptoide
Edit: Quickly replaced the Beelink with the Tronsmart Vega and download speed is back to my download cap of 25Last edited by 4WheelSpyder; 08-27-2014, 12:05.
Ok guys, seems i have a problem. I change my router, and ethernet does not work. On the other devices(tronsmart vega, minix x7, laptop, desktop) works.
I've disabled wifi, but nothing. I've even change 3 cables(cat5,cat6).
It may be my internet provider that blocks something. I will try tonight to reset my router.
Any ideas
AW: R89-WIFI/BT/Ethernet feedback here
Originally posted by 4WheelSpyder View PostWhat do you folks use to test your internet/wifi speed? I normally use ookla's Speedtest but PlayStore tells me it is not compatible with this device.
Paired the device with a bluetooth RocketFish mouse and I am using it - no problems to report
Also paired it with a Nexus 7 (2012 - KitKat) but I have not really tested the interface
Edit: Check the attached files from here to know what to change, but better not use the files directly:
Tested streaming music with Google Music on bluetooth.
Xqisit LZ380 Bluetooth 2.1
+ Pairing went well, good quality with sound
- stuttering when doing "stuff" like browsing Google Chrome, closing tabs, scrolling etcBeelink R89
Pioneer SC-2022
Samsung 55" LED 2012
Previous:
Minix X8-H
Minix X5
Logitech Revue
Ethernet not working
After a factory restore Ethernet will not connect again. When it works, it is fast. Also, there has always been a lag, ex. When I open XBMC and access my files from my synology NAS, it takes a minute or so to connect. But when it does connect, it transfers the files 3 times faster than base 100.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by TMx View PostMiracast - Wifi-Direct Working Quite Decent with my LG G2 Mobile Phone...
pixelated image time to time so there might be a room for improving.
Compare to the Other Boxes Its Great
Originally posted by clarkss12 View PostAfter a factory restore Ethernet will not connect again. When it works, it is fast. Also, there has always been a lag, ex. When I open XBMC and access my files from my synology NAS, it takes a minute or so to connect. But when it does connect, it transfers the files 3 times faster than base 100.
Anyone else can confirm this?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostIf it could communicate between your phone and R89 via 5G channel...I think it'll be more decent
If there are many files in your NAS...XBMC will take some time to load it..
Anyone else can confirm this?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I am using this R89 box as a PVR (DVR) with the back end running on my Synology NAS connected via Ethernet. With this box's gigabit speed, my full 12 days of guide data loads in 4 seconds. That is fast.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Ethernet not working after Static IP setting attempt
My Ethernet connection was working flawlessly, although at a choked speed. In order to change the dns settings I changed the setting to Static IP and copied everything over IP, Netmask and Gateway, set dns1 and dns2 to the new settings, saved the settings and although the settings are displayed correctly, there is no Ethernet connection. Cancelling the Static IP setting did not bring the connection back. (all settings are displayed as zeroes) Cancelling Ethernet and switching over to wifi, which was still working, and back to Ethernet did not restore it either. Also tried rebooting a few times. No luck!
There are currently 2108 users online. 5 members and 2103 guests.
