R89-WIFI/BT/Ethernet feedback here
Originally posted by Hui91 View PostRK3288 Devices
- Overview BOX (LINK !)
Ehernet Problem
In general, my R89 is working well but my Ethernet is not working properly. The WiFi works great but I moved it near a gigabit switch and thought I would do better with hardwire network.
What I have seen so far is the box crashes after 5 minutes or so when Ethernet is plugged in and enabled. This is with WiFi disabled as well. The Ethernet MAC address changes after each crash as well. Pretty strange.
I saw that some have mentioned issues but it did not seem that the issues have been addressed yet. Seems like the WiFi working so well has lowered the importance of fixing the Ethernet issue.
I'm on the latest (I believe) stock firmware 110K4
Thanks for any help...Brad
Originally posted by BP-isMe View PostIn general, my R89 is working well but my Ethernet is not working properly. The WiFi works great but I moved it near a gigabit switch and thought I would do better with hardwire network.
It's strange.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
5 Ghz?
Originally posted by no_spam_for_me View PostI think the improvement will be at 5GHz and specially at 11ac but not at 2.4Ghz...Beelink R89 PCB V3.0
Running on Finless V1.2 at the moment
I only know iperf which should also work at wifi and also at 5GHz (why not?)
and there also exists OOKLA
http://www.freaktab.com/showthread.p...l=1#post248717 (it use also the ap6335; but of cause you need good/high speed at your ISP...)RK3288 Devices
Yes it's strange
Originally posted by oman View PostThe Ethernet MAC is WIFI MAC + 1...But you mentioned that the Ethernet will changed after each crash?
It's strange.
Brad
wifi link speen
Hi guys,
I have done a little experimenting, and found that if I move the device during heavy wifi usage (like speedtest), it kills the reception. I mean move, like you turn it over to plug in an USB for example and place it back to the same place.
The wifi link speed is 150 mbps at the beginning (although pass-through is only ~40 mbits), and it drops to 13 mbps (resulting very slow connection). My issue is that the android box does not increase link speed back to 150 (unlike mobile devices when you come closer to router it gets faster). I need to reconnect to wifi to get fast connection again. I experienced this in stock, Finless and Wasser roms.
Does anyone has similar experience? Is my device hardware/wifi faulty? The worst I can think of is bad soldering of wifi antenna or something like that which affects the performance when I move/turn the device...but I dont know, help please!Beelink R89 PCB V3.0
Does anyone has similar experience? Is my device hardware/wifi faulty? The worst I can think of is bad soldering of wifi antenna or something like that which affects the performance when I move/turn the device...but I dont know, help please!.
BTW,if you reboot the box after moving closer,how about the result?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostIMO,the box should be in one place all the time,it's not mobile.
BTW,if you reboot the box after moving closer,how about the result?Beelink R89 PCB V3.0
Originally posted by Hui91 View PostWhen it is not moving mostly okay, but still sometimes for some reasons (interference, heat, or idk) when the speedlink drops down it won't negotiate to have a faster connection back. Usually reboot/reconnect solves it, but still annoying, especially during online gaming.
I wonder if it'll be better within 5G channel ..
Or does anyone else have such problem?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Or does anyone else have such problem?Beelink R89 PCB V3.0
Wait, "wifi analyzer cannot see any channels on 5 Ghz. ... My router is 2.4 Ghz only", how do you want to test 5GHz without a 5GHz network? Are you sure there exist any 5GHz network around you?
???RK3288 Devices
5 ghz analyzer
Originally posted by Hui91 View PostYes I have AP6335, but for example wifi analyzer cannot see any channels on 5 Ghz. How can I check 5 Ghz then? My router is 2.4 Ghz only, but I might invest in a 5 ghz if it definitely improves things!
Got to Fluke Networks. They have a trial download of Airmagnet that will analyze both bands. I was able to see what channels of 5 ghz are being used in my neighborhood and choose an empty one on my router.
Originally posted by no_spam_for_me View PostWait, "wifi analyzer cannot see any channels on 5 Ghz. ... My router is 2.4 Ghz only", how do you want to test 5GHz without a 5GHz network? Are you sure there exist any 5GHz network around you?
Originally posted by TheDemby View PostGot to Fluke Networks. They have a trial download of Airmagnet that will analyze both bands. I was able to see what channels of 5 ghz are being used in my neighborhood and choose an empty one on my router.Beelink R89 PCB V3.0
oman
Please make it possible to enable wifi and ethernet at the same time.
Currently, when you enable both, the stock-Android will disable the non-preferred connection after a certain time (~2minutes). There is a discussion on the stackoverflow forum on how to work around this, here. Please implement this in your Rom. The Beelink devices are TV boxes and not mobile devices. There is no need to save battery or watch cellular data plans.
Thanks!
There are currently 2133 users online. 1 members and 2132 guests.
