R89-WIFI/BT/Ethernet feedback here
IPerf - In-house network testing and performance measurement tool
=> http://www.freaktab.com/showthread.p...l=1#post170864
(https://play.google.com/store/apps/d...ps.iperf&hl=en)
If you use e.g. openWrt at your router, then you can also run iPerf at it...RK3288 Devices
- Overview BOX (LINK !)
AP6335 is really good in R89. Comparing to AP6330 in S89:- AP6335 and AP6330 have similar range. I get a "fair" 5ghz signal from my Netgear R7000 in the 2nd floor of my house to either TV box in the basement. 2.4 ghz signal is a bit stronger on both, but connection on that band is slower.
- AP6335 has faster speed, getting 35 to 40 mbps down and 12 mbps up on 5 ghz at that range. AP6330 in S89 gets 15 mbps down and 10 mbps up in the same spot on 5 ghz.
Originally posted by FadeFx View PostI would use "cooltool" and transfer files from one device tothe otherOriginally posted by no_spam_for_me View Post=> http://www.freaktab.com/showthread.p...l=1#post170864
PS Iperf worked like a charm - exactly what I was looking for. Thank you no_spam_for_meLast edited by 4WheelSpyder; 30 August 2014, 16:30.
Originally posted by clarkss12 View PostAfter a factory restore Ethernet will not connect again. When it works, it is fast. Also, there has always been a lag, ex. When I open XBMC and access my files from my synology NAS, it takes a minute or so to connect. But when it does connect, it transfers the files 3 times faster than base 100.
Originally posted by clarkss12 View PostI swapped cables and got Ethernet working...RK3288 Devices
Originally posted by 4WheelSpyder View Post
Running a wired Ethernet setup - Ookla reports 9.5 down which is less than half my normal download speed. Up is 2 which is my cap.
Edit: Quickly replaced the Beelink with the Tronsmart Vega and download speed is back to my download cap of 25
I will see if I could replicate the issue that I had with the Static IP settings.Last edited by 4WheelSpyder; 30 August 2014, 22:01.
Wifi Antenna Patch
Hi oman, kudos for placing the antenna patch at the top if the box lid - way to go! This box wont have the same wifi sensitivity issues that so many tablets are having.
PS, The Ethernet on my box is down againLast edited by 4WheelSpyder; 31 August 2014, 02:46.
Originally posted by 4WheelSpyder View PostMy Ethernet connection was working flawlessly, although at a choked speed. In order to change the dns settings I changed the setting to Static IP and copied everything over IP, Netmask and Gateway, set dns1 and dns2 to the new settings, saved the settings and although the settings are displayed correctly, there is no Ethernet connection. Cancelling the Static IP setting did not bring the connection back. (all settings are displayed as zeroes) Cancelling Ethernet and switching over to wifi, which was still working, and back to Ethernet did not restore it either. Also tried rebooting a few times. No luck!
We met this situation before,and we fixed that..
Could you give me more details?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Wifi is having a bit of a problem. I am only getting choked rates as at the beginning. When I run an ookla test the test would start at say 6 Mb/s and then taper off - to the point that it would sometimes stop and state "network error" It happens on both routers in my house. One runs DDWRT and the other runs the OEM firmware. Even when it states 'network error' I could still exit ookla, use a browser and I would have internet access. It is almost as if some buffer is being filled up.
Will post more info once I have it.
Update: I have run a few ookla tests and my download speed is now 1/2 the upload speed. (Down to just over 1Mb/s) Replacing the Beelink with the Tronsmart placing it on exactly the same spot provides a more than 10 times increase in download speed.
Now here is maybe a pointer. If I power the Beelink R89 down and back up, the first time running the ookla tests it register a download speed of 10 Mb/s, however running the same test the second time and the download speed is back down to 1Mb/s.
Switching over toe Ethernet and the speed is back to almost my cap of 25Mb/s\
Just for the record. Wifi Analyzer registers -45dB (solid green) and there are no other transmitters at the same frequency.Last edited by 4WheelSpyder; 03 September 2014, 01:59.
Originally posted by 4WheelSpyder View PostNot sure what is going on, it appears as if the wifi and Ethernet are playing tag. Ethernet is fairly solid now.
Speedtest Version: v3.2.3
AW: R89-WIFI/BT/Ethernet feedback here
Originally posted by userx View PostThis is a good web test... http://testmy.net/
You can test many diff configurations.
TiP Data Points:: 8.52 Mbps, 10.19 Mbps, 10.51 Mbps, 10.46 Mbps, 10.56 Mbps, 11.13 Mbps, 2 Mbps, 1.04 Mbps, 0.91 Mbps, 0.87 Mbps, 0.9 Mbps, 0.91 Mbps, 0.68 Mbps, 0.95 Mbps, 1.45 Mbps, 0.95 Mbps, 0.95 Mbps, 0.93 Mbps, 0.53 Mbps
There are currently 1706 users online. 1 members and 1705 guests.
