Please keep in mind that I put this rom together for my personal use, so you might not agree with the settings or the apps (very few) I have pre-installed, but lucky for you, you can modify/uninstall all of them with ease
a few features:
- Xbox 360/Ps3 controller support, modules compiled by me, I've tried the Xbox wired and wireless (with the USB adapter)
- GAPPS pre-installed
- build.prop tweaks (thanks to Finless) The stick will identify itself as a google TV device, but you can download any app from the store
- SPMC is pre-installed, as it was the best XBMC I found for the stick, it runs 1080p movies without a problem
- Very streamlined ROM, no watchdogs, no background running apps, but this also means you have to manually pair your gamepad
- init.d support
- XBMC permission fix (thanks to Ant)
- Many other small tweaks
- Remote IME support
How to install: (you will need a USB keyboard)
Copy the firmware to an SD card and put it in your gamestick.
Disconnect your gamestick from the USB power.
Using your fingernail (I use a paperclip) press downward on the little button besides the USB. Alternatively, if you can, install Quickboot, and reboot into Recovery
While still pressing the button, connect the USB power and wait around 5-10 seconds, you should see the recovery screen.
Select the second option, then Sdcard, finally select the FW
it will start installing, make sure you don't power off your gamestick until it finishes!
Reboot and you should be set, I recommend after the initial setup reboot your stick once again.
The risk of bricking is VERY small, but I guess its still possible so flash this with caution and do it under your own risk, I am not responsible if you brick your stick
You can always return to stock ROM the same way
And if you use this, please let me know if you find any problems.
