[ROM] Gamestick CFW v1.3 :)
Originally posted by niabi View PostI will try this tomorrow, and you are free to use my rom as base. I can share the unpack boot.img scripts as they are not the standard ones available
i get it stable here in my bedroom (where I'm testing) and then move it out to the living room, and it won't boot. I've restored it twice, each time it's fixed it. I'm going to try again
thanks. I'll keep an eye out for a link to the scripts, and use it as my base. I appreciate it.
I compiled the CIFS module (cifs.ko)
Download GApps, Roms, Kernels, Themes, Firmware, and more. Free file hosting for all Android developers.
MD5: 10d5316552a148010d0694577e18cbd6
although the rom already supports SMB, since I use it on SPMC andwith ESFilemanager to access my windows shares.
and here is the extract/pack scripts that I use
MD5: 98be760a359ee71543e8e322cf6c4a37
enjoy
Originally posted by abo1787 View PostYou're freaking awesome, thanks for the quick reply. I'm currently running into all sorts of issues with this stick.
thank!!
I hope to get to work on these soon. I was looking at the requirements to compile a kernel, and I don't currently have the environment space setup. But I hope to get it soon. Just gotta find some free time.
Really appreciate it, and I'll let you know how it goes.
enjoy
I have been making progress on getting Adroid 4.2.2 on the Gamestick, and making the CPU run at 1.2 ( instead of 984mhz)
so far I have:
Wifi Working
CPU at 1.2g (same governor tho)
I do need help on getting Bluetooth working, anyone familiar with enabling BT on android? I know I have the drivers and files needed, I just can't get them to work
Code:service hciattach_amp /system/bin/hciattach_amp -n -s 115200 -f /etc/bluetooth/BCM40183B2_26M.hcd -m /data/misc/bluetooth/bt_addr.conf /dev/ttyS1 bcmbt 2000000 flow
Code:"service: Unknown command hciattach_amp"
and
Code:/system/bin/hciattach_amp -n -s 115200 -f /etc/bluetooth/BCM40183B2_26M.hcd -m /data/misc/bluetooth/bt_addr.conf /dev/ttyS1 bcmbt 2000000 flow
Code:start reset bcm2048 Initialization timed out.
Can I flash this throough a flash drive connected to the usb port on the y cable? i found anothe rsite that was discussing this and there were severall differnet reviews, some saying this did not work at all, others saying it worked, but you had to leave it unplugged from the tv's hdmi port or the recovery screen would flash on for a moment and then go to the usual screeen. Just wondering because i really would rather use a flash drive which i have, than buy a whole new sd card.
There are currently 2702 users online. 0 members and 2702 guests.
