UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
Hi Bob
Thanks for the provided rom
I have the following issue, after the upgrade of the firmware the device is marked on the google play as china mobile, as results of that I am not able to download some application, can I do something to change that or I have to re=run the procedure for modification the framework.jar
Regards
Regards
Markey enabler will work. My next ROM release I will do the china moble mod. I did not know about this issue and this does not happen on tablets for some reason. So next version will have this fix.
Also guess what guys! I just got a working ClockWork mod going today
Stay tuned I will have an update kit out today.
Now remember this! By installing CWM, you will not be able to update from sdcard using the stock update.img! But you will have CWM!
Market Enabler or any benchmark app reboot the stick. It's was that way with stock and same with this rom. Any idea? quite annoying.
Finally figure out my problem, it's the power. After using an external battery, the stick no longer crashes.Last edited by max1001; 28 September 2012, 00:01.
jwz, I am sorry man but I cannot dfix this. It is a hardware thing. Because this device has no battery, it cannot be shut off from software. As long as it is powered, it will boot back up. Thatis the way it is for now.
I wish too to solve this issue but for now I cannot.
Originally posted by max1001 View Postwhy not just get an wall plug adapter with on off switch you get at the dollar store?
You can even get one with a remote for around 7-10 dollars online.
Originally posted by Finless View PostInteresting reports.
As for the flash player. That thing ticks me off. Sometimes after a ROM flash when you open the browser for the first time it will install OK and you will even see the message that it is installing. Other times it does not. The BEST way is for me to remove it as a system APP and you guys just install it as a user APP. This always works!
In the older Flash version 11.1.115.11 this menu pulls up... (see pic) and allows for streaming flash content from web browsers. Adobe is cutting the Flash plug-in support cord and this version is the last working version. Please remove the pre loaded Flash version from System Apps to allow users a fix. Thanks
Also audio and video sync are way off in this ROM as others have mentioned.
Not sure why but it been their from the beginning with UG802s.
But have noticed it being worse with this ROM.
Thanks for you work, it's much appreciated.
aaaa i have bad karma with my deviceyesterday i receive it, and first i want to put Finless ROM on it, i
do everything in txt file.
1.put the ug802 into flash
2.Driver install
and stop on this step from readme.txtž
"...11) At this point the drivers should install. If not start over.12) No matter what, reboot the PC now. Also unplug the ug802 and let it reboot.."
i reboot my pc and when pluging ug802 out i broke micro usb connector
today i was in electronic store, and they succed to fix only power connections but not
data connection on my micro usb connector on ug802, so what i want to ask
is it possible now to connect ug802 on power adaptor with micro usb (hope that power is working)
and finnished with puting custom rom connecting my pc with usb2 connection ?
so i have pc, pc is conected with normal usb and ug802, and power is comming from power adaptorconnected with micro usb on Ug802
what a mess
working with ubuntu
im currently running ubuntu is there any special instructions on getting this to work or will i need to find a windows based computer to get this to work. i suppose i could search for a how to guide for something else and go off of that i was just looking to see if you had a write up thanks.
Originally posted by userx View PostI also found that your Flash version 11.1.115.17 as a system app does not allow to be removed.
ivana, I do not know if data can work over the other USB port.... I can try later when I get home from work.
Not sure the question about Ubuntu?
There are currently 2389 users online. 1 members and 2388 guests.
