hi finless pls help me.
you say connect the ug802 with usb cable (so micro usb entrance and on pc normal usb entrance) to the pc. i did it, but then you say go to the menu? Should i plugin the stick in the tv or what? cause you didn't say this :S
And how can i enter the internal sd? with a male to female usb ?
the problem appears on every video, flash, external sd and so on..
