UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
Originally posted by alexinc View Posti'm using droidmote without problems on this rom... so uinput.ko is included!
Thanks again for helping me show others that uinput is not the issue
Vielen Dank für Ihre Hilfe Alex
I have a feature request finless if you can... i would like the ability to mount loop devices in the kernel. i noticed another user on this thread who said they chroot loaded ubuntu, but i can't seem to get it to work in the v1.4 rom because of a lack of kernel ability to mount a loop device. every time i try, it gives an error of "mounting .... failed invalid argument". my directory names are correct, if i try to run the linux on android complete launcher or a terminal loop mount command "busybox mount -o loop /mnt/external_sd/ubuntu/ubunutu.img /mnt/linux", i get the error. how do i check for loop support in the kernel? is it possible to add it in? also, how do we add true 1080p as a resolution? it only goes up to 720p despite telling me its 1080p.
Re: ug802 Android mini PC TV Player - Finless ROM 1.4 Custom ROM
Originally posted by grindy View PostI have a feature request finless if you can... i would like the ability to mount loop devices in the kernel. i noticed another user on this thread who said they chroot loaded ubuntu, but i can't seem to get it to work in the v1.4 rom because of a lack of kernel ability to mount a loop device. every time i try, it gives an error of "mounting .... failed invalid argument". my directory names are correct, if i try to run the linux on android complete launcher or a terminal loop mount command "busybox mount -o loop /mnt/external_sd/ubuntu/ubunutu.img /mnt/linux", i get the error. how do i check for loop support in the kernel? is it possible to add it in? also, how do we add true 1080p as a resolution? it only goes up to 720p despite telling me its 1080p.
Sent from my SCH-I535 using Tapatalk 2
Originally posted by abkulp View PostI get true 1080p on the 1080p display setting... I'm not sure why you wouldn't. Make sure the settings on your TV/monitor are correct.
i also cant edit my pixel density down to 120. i can change it in the build.prop or use lcd denisty changer and it still is at 160. on my mk802 (allwinner cpu) i have it set to 1080p @ 120dpi and it looks and works great.Last edited by grindy; 11 October 2012, 01:58.
Originally posted by grindy View Posti hate to say it, but you think you are getting 1080p. Your TV reports its 1080p just like mine does, but load xbmc or antutu benchmark or android system info and you will see it is 1280x600 something...you lose a little vertical res cause of the status bar. if your ug802 is behaving differently, i would be more than surprised and will beg you for your kernel and firmware
Sent from my Samsung Galaxy S III
Originally posted by abkulp View PostOooh, I see what you're saying. The UG802 is outputting in 1080p, but video cannot be seen in 1080p. The problem is the system bar. If you install hidebar you can get 1080p resolution. Unfortunately, it doesn't allow you to show the bar again, and it's a tad glitchy, but I'm dealing with it for now. I watch netflix in full hd all the time. Hopefully in the near future Finless Bob or someone else can figure out how to toggle the system bar more effectively.
Originally posted by grindy View Postthats not what i mean..true 1080p is 1920x1080 pixels res. ug802 outputs 1280x672 pixels res. even when set to 1080p and even when tv reports it to be 1080p it is really 1280x672. hidebar only makes it 1280x720.
Originally posted by Daved View PostWe are getting 720p. I'm using the UG802 on a 24" monitor and it's very easy to tell the difference between 1080p and 720p, no settings get us 1080p at the moment, the apps are telling us the truth about the screen size.
Originally posted by harryharryharry View PostWell then the specs retailers use to sell the device are in fact false advertising, right ? Is this a hardware or software issue ?
There are currently 2430 users online. 1 members and 2429 guests.
