UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
Originally posted by azboxhd View Postor to selection of launchers like first time when i put finless ROM on my device.
solving the audio video sync problem!
Originally posted by bravomail View PostAV sync issue could be related to the implementation of HDMI in UG802. It certainly can be fixed in software. But it won't be easy. I don't know if Finless is armed enough to fix it. It could be at kernel level. Some googling and asking around might help to implement it in future ROMs. Another sure way of fixing it is to put AV receiver between UG802 and TV, and then program audio or video delay to achieve desired sync.
If there are media player like BSPlayer to support custom setting like that - very good.
My hopes are high with JellyBean because Google made it to have less latencies. So it might fix AV sync issue alltogether.Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
to Finless - System is mounted as RW
Couple of thoughts after installing your ROM, Bob:
1. It seems that it's based on earlier versions of UG802 firmware, I notice less stability, but stronger WiFi signal. I can live with that!
2. System partition is mounted as Read/Write while it should be Read-Only. It can lead to all kinds of corruption of the system and eventual degradation. Root Explorer could not remount it back to RO, which is really weird.
3. For people looking to restore original firmware - lookup ARMTVTECH website. It has 3 different firmwares available. http://www.armtvtech.com/armtvtechfo...wforum.php?f=5
As for Market fix,
Try putting/replacing following into /system/build.prop:
ro.product.model=GT-N7000
ro.product.brand=samsung
ro.product.name=GT-N7000
ro.product.device=GT-N7000
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=GB
ro.board.platform=exynos4
ro.build.product=GT-N7000
ro.build.description=GT-N7000-user 4.0.4 IMM76D XXLRT release-keys
ro.build.fingerprint=samsung/GT-N7000/GT-N7000:4.0.4/IMM76D/XXLRT:user/release-keys
ro.com.google.clientidbase=android-samsung
#Enable GPU Acceleration
debug.sf.hw=1
video.accelerate.hw=1
debug.performance.tuning=1
persist.sys.composition.type=gpu
Galaxy Note N7000 has Cortex A9 CPU with Mali GPU - just like UG802 RK3066. And its display resolution is 1280x720. So it's a good match.Last edited by bravomail; 02 October 2012, 15:48.
Hey guys I am out of town for a week but next week I will have a JB ROM for you all to try.
Yes this ROM has uinput. I have not used droidmote but I have used VNC, etc.
To make sure you uinput module is working, download a terminal emulator for the market
run it
type su at prompt
now type lsmod
This will list all KO modules installed and running.
cambel, when you login to this site at the top click the box "keep me logged in" you should have no problem downloading then.
Be back soon all.
Go into settings and and storage. Make sure storage is mounted. If you get an error then format storage and try again. Internal SDcard must show up as a drive to windows.
Originally posted by Finless View PostHey guys I am out of town for a week but next week I will have a JB ROM for you all to try.
run it
type su at prompt
now type lsmod
thanx
Originally posted by lil_y View PostThere is no uinput module listed when i type this, or when i search for it. Can someone please upload the uinput.ko file so i can insert it
thanx
Bob, before you drop you JB ROM is that something that you can confirm that there is uinput.ko in it. If it isn't is this something that has to be coded into the kernel, modded for this ROM, or just a Universal module that gets dropped in the ROM.
Otherwise I guess we can always ping zulu for some assistance with the JB ROM when Bob drops it on us.
Thanks for the work thus far.
Looking forward to the JB update, and cheers for your work on it thus far. I'm still running stock, so will wait for that update to come along.
For me wifi is usable for the net (although very slow) and things like Youtube etc or browsing nfs shares is pretty much unusable. I hope this can be fixed (but it's looking unlikely I guess without modifying the internals?)
Slightly OT, but does anyone have a USB hub recommendation that can be used? I've got a MS adapter (not externally powered) that doesnt work. Ideally I'd want two to three devices hanging off of it. Im guessing it has to be externally powered, which doesn't bother me.
If that doesn't work, what recommendations are there for a full size wireless/mouse combo?
i have usb hub whitout external power and everything work ok, but you must use hub with cable i buy hub like box whitout cable and with that hub i broke mirco usb adaptor inside device, so after some repair in electronic store, power working thru usb but data transfer not ! so i was not able to update thru pc only thru sd card.
Originally posted by Finless View PostGo into settings and and storage. Make sure storage is mounted. If you get an error then format storage and try again. Internal SDcard must show up as a drive to windows.
Still having the same error message. Is that any suggestion or procedure?
Regarding the Audio/Video sync issues on the UG802.
I have this setup:
UG802 (fully rooted, but not with Finlessbob's ROM)
32gb SanDISK Ultra micro-sd card class 10
Connected to a TV with 1280x720 resolution
I got the 802 a week ago, and I have been trying to wrap my brain around the sync issues people (me included) seem to be having. From what I can tell, the desync is the same no matter what player I'm using. I've tried BS player, MX player, VLC and they all have the same desync; maybe a quarter of a second off. In order to make sure it was not caused by my sd-card class 10 because it caused lag or something, I moved a 720p .mkv file to my flash drive and experienced exactly the same amount of lag there. When I browse YouTube, same thing there. The movies I play have an AV desync of about a quarter of a second.
All this makes me believe that the culprit is either one of two things;
1. Hardware issue.
2. Some software that runs in the background, that effects all videos being played from the device.
I feel like number two is more likely than number one, and I will try to look into what actually comes with the UG802 so I can maybe find out whats causing this. On windows we have videoplayers that can sync video with audio by setting a delay, but I haven't found any on the Play Store for andriod. I also get one other problem when I install other videoplayers; black bars on top, left, and right side. It's like it won't fullscreen. When I play movies with the videoplayers that came with the device I dont see these black bars.
Any help towards any of the two issues I'm having is greatly appreciated.
There are currently 5680 users online. 1 members and 5679 guests.
