UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
We are working on 4.1 as we speak. I just made a bootable ROM made from the MK808 4.1 dump that Heap provided me. Only problem so far is getting wifi working which should not be too hard we hope!
At the top of this web site logout. Now at the top login and click the box at the top that says "keep me logged in". Should work then!
Re: ug802 Android mini PC TV Player - Finless ROM 1.4 Custom ROM
if you login you must click ''remember me '' otherwise it will not work
Verstuurd van mijn ARN10bG3-FreakGenTab met Tapatalkif you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
Originally posted by thehiq View PostToo bad, the rom works fine, but the problem with the Sound sync issues is unfortunately still there.
I think it's the kernel, as it is with any Rom, every player and every type of movie (Flashmovie on website, mkv, youtube).
Is there already a newer kernel?
Use hw for video decode (not hw+) and sw for audio decode
ok update to my problemi flash stick with sd card, pc connection not woring with f2f usb cable
i confirm that market enabler reboot stick, so i can't donwload some apps that's it for now, i'm playing hole nite with this, friend send me some app files to my gmail but i can't see attach. is this usual ?
try bs player it has lots of options and you can audio sync 200 milliseconds (2 seconds ahead) and audio video is fixed you find the setting in the menu only when the movie is playing you will get a slider when its foundMinix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
Originally posted by thehiq View PostOkay, thank you.
But when I look at the browser Flash movies, then do not even syncron.
Speaking of flash, works your flash? This is on the rom installed, but it is not displayed on web pages.
I am going to work on it. It is either a crappy media decoder library or a hardware problem. If hardware not sure what I can do. Again I am looking into it.
Does it do this sync issue when vidoes are on internal SDcard?
I want to make sure external sdcard buffering is not the problem.
There are currently 2308 users online. 0 members and 2308 guests.
