UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
    Originally posted by mobicom View Post
    My ug802 came in set with this usb to lan and work very well, but I'm still on stock firmware waiting for 1.5 from Bob
    http://www.****.com/itm/USB-to-RJ45-...item416a5a2b01
    I fully test everything I do so it takes some time. But I am expecting to have 1.5 out tomorrow.
      Please make a nicer boot screen as someone else said before Thanks a lot.
        OK, I get this "ask" all the time. And what exactly is a nicer boot screen?
        TRUST ME... everyone wants something different. So what you consider a "nicer" boot screen another may not!
        But then I go to this question. For as SHORT as the boot screen etc is up, does this really make a difference vs what I do in my ROMs to make the user experience better?
        I mean really? Is it that important?
        OK so I will ask my friend Tattman to cook up a boot screen. But you all better help him with what you want! I will link you to a post he will create when I ask him.
        But I still am confused by this constant request! A "nicer" boot screen. NO ONE has ever explained to me what that is
        More it seems like a bunch of art critics that cant decide
          wireless remotes?
          First of all - Thanks for being a dev for something not mainstream. This forum has been a great help.
          I've tried using the following remote with the UG802 (connected the wifi module directly to the usb port and also via a usb hub). The remote works, keboard works perfectly.
          However, every few mins the pointer disappears at the bottom of the screen and swiping or moving finger up moves the pointer up but it slides right back down instantaneously.
          Most evident when opening playstore or anything that accesses wifi-usb
            I made a new thread for boot screens for TV players. So you guys discuss all you want. In the end Tattman will make my boot screens for now! Love them or hate them.... only your feedback to him will make a difference!
            Tattman, I am not sure what you signed up for my friend.... It seems 2 seconds of someone's life is a big deal! Damn art critics
            http://www.freaktab.com/showthread.p...ot-screen-work!
              The original MK808 boot screen is really nice, it's a simple Google TV logo. Add your logo to the right bottom corner, and done. My opinion.
                thats great
                What chipset does it have inside?
                  +1 on this one
                    launcher
                    boot screen is not important for me, it takes just about one minute.
                    a better launcher is more important.
                    like this
                      Hello Finless Bob,
                      you did a great work with the V1.4. I like this much better than the original.
                      I have noticed is that I get more the message. "wait or cancel"
                      in your kernel is actually also the CIFS module? unfortunately not employees of Mount Manager properly with my NAS: (
                      Keep it up, I like your work
                      Will be the v.1.5 Jellybean, or even ICS?
                        JB will come with 2.0 ROM version
                        P.S. I will have a 2.0 ROM version when I get JB from ugoos. So ICS will stay at 1.X so just an FYI how I name my ROMs.
                          Thank you!
                          I do thank you Finless for the ROM. I was very disappointed when I thought I was going to escape the Roku 2 Box cage and get full control over my TV only to setup my MK802 and find its Android is locked into Communist China. I have excellent tablets direct from China but they all shipped with regular Android, Browser, & Google Play.
                          I found out about your ROM & wasn't angry anymore. One problem. For some reason the Rom did not root Google Play. I no longer see all the Chinese apps and I can download Dolphin (which solved my YouTube problem) but I still get the block on Netflix ("not yet available in your country") & I had to download and play with ES Explorer to find and launch your app page. The Chinese apps remain and many of your Rom installed apps will not open.
                          I can't find a post where anyone mentions these problems or this thought. I'm wondering if I should eliminate Google sync (backup & auto restore) & try SD Card installing Rom 1.4 again, or just wait and install new ROM 1.5?
                            I applied one of the fixes to play store in 1.4 but I did not apply the telecom fix from deadhp1. I will do that in 1.5.
                            As for the china apps still being there, It means it did not flash my ROM properly via update.zip. Make sure your SDcard is not corrupt and watch for errors while it is updating.
                              ROM Install Issue
                              Bob,
                              Thank you for you quick reply. I erased and recopied the 1.4 Rom three times and today I downloaded it again, this time from a different computer. No go. It does go through the install process. It seems to me that it does the job rather quickly considering that it is rooting the UG and then installing. I have been using the same Sandisk SD card which hasn't seen much use. The three music video files on it work well. There is a lost directory file but I didn't think that can interfere. I'll order some new SD cards and try again.
                              I assume my UG 802 is the same as the ones others have successfully rooted but one question. People here refer to the R UG802. Mine doesn't have any R or word begining with an R. Also, I have zero wireless problems & it gets slightly warm, never hot with use. The seller I bought it from ordered it direct from China for me two weeks ago. Given his excellent service, I am sure it was made in September.
                              I am reluctant to try the flash version of your ROM, given complaints I've read here. I have no video, flash or Wireless issues & dont want to risk any. By the way, I tried a factory restore with SuperUser. It seemed to go through the motions but nothing changed.
                              I think my screen shows each step taking place and I get the reboot and "successful" message each time. I cannot read the entire lines though as they start off my TV screen.
                                Please duoble check your SDcard! See this post.
                                http://www.freaktab.com/showthread.p...Understand-WHY!
                                What I am talking about is a easily corrupted FAT32 files system on SDcard. Just because you can see files does not mean there is not a problem! 3 people so far had problems using update.img because of a corrupted SDcard file system. Read up about 10-20 posts and see. Update.img version is VERY picky about SDcard corruption. Most people do not even know the sdcard is corrupted until they look!
                                Anyway, please read this post on how to check and fix your SDcard. Make sure that is good first.
                                No one else has reported a problem like yours. So if it is not your sdcard, then I am not sure. Works for everyone else so far.
                                BTW the PC flash version does only ONE change vs the update.img version. It gives you more APP space period. Nothing else! So whatever works or does not between the 2 is inaccurate! They are identical ROMs functionality wise.
