UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
Originally posted by cydergoth View PostHi Bob, great rom, much better than the stock! One question - I need tun.ko to use VPN to my work with this UG802 build. Do you have a tun.ko build? I tried "tun.ko installer" app which has a database of them and it didn't find a compatible one? Thanks
Any ideas how to solve this?
Originally posted by Snowcrash View PostI installed the rom and everything works fine !
I have a question for you guys: i'm using Airmouse RC11 but i don't like how it works, any suggestion for me ?
Thank you very much from Italy
Originally posted by valcs View PostWhich part of it's functionality do you not like, what do you want to control?
Are we OT ? If yes i finish immediately to talk about mouse
Originally posted by Snowcrash View PostKeyboard is quite good, not perfect but usable. The mouse pointer sometimes, often, loose alignment and to move the pointer i have to rotate the device 20° on the right.
I am still investogating how to play games like X-plane or driving games or emulators. I have ordered a usb game controller. Not that I wan tto game, I am just curriouse and want to see what can you do with this little guy.
Originally posted by valcs View PostWith Finless 1.4 ROM I use Droidmote, although it is very laggy. Sometimes I use wireless mouse, and sometimes the airmouse. I am getting used to the airmouse, but I agree it is pretty bad. Especially when you sit a bit further. The keyboard is not that responisive.
I have a galaxy s3 and installed client droidmote
but on ug802 what should I install? I can not find a server version for Android
thanks
thanks
Originally posted by valcs View Postyou probably installed the Finless Rom 1.4 the "easy way". If so, you have to root your UG802 and apply the store fix. There is plenty about it in this thread, but basically the UG802 thinks that you are in China and does not show you the apps for your region. You have to change the "cell provider code". Or you can wait for the final Finless ROM 1.5. I think it is going to have the storefix already built in.
else some other apk that does the same thing??
thanks
I've upgraded to this rom in hopes that some tablet apps will finally work on the ug802, unfortunately they still do not work. the tablet versions of sunday ticket and slingplayer do not work. with both apps they start and do not FC but when they are to play video the circle just spins and spins and video never stops. the phone versions of both apps work but these tablet versions will not.
any idea why these apps will not work on the ug802. really sucks because these apps are the only reason i bought the device.
Unable to install Storage-Drivers required for PC-Flashing
as mentioned above i can't install required drivers for Win XP.
i repeated all the steps are written in the "manual" which is included the Firmware several times.
The message unknow USB-Device pops up, but if i select the Driver included the Firmware-Archive i get a message "no Hardware-Information found" and my unknown USB-Device stays as an unknown USB-Device.
In WinXp it is shown as RK30SDK
By the way i have already installed Firmware 1.4 using SD-Card-Method.
i hope there are not so many mistakes written
kind regards from Germany
There are currently 1845 users online. 3 members and 1842 guests.
