UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
    Flashing 2darkFW_on_Finless14a now
    --edit---
    well, using this as a test video http://www.youtube.com/watch?v=6TiXUF9xbTo&hd=1
    YouTube seems perfectly in sync
    Right-click to go 'back' doesn't work - it's a mouse with two left buttons
    **EDIT
    actually, it's changes function, sometimes it's a context menu ???
    Last edited by plushsat; 31 October 2012, 01:49. Reason: edits as I go about using it
      is the firmware compatible with the easy way (500 MB) or via a PC (1GB)?
        I can get everything to work like a charm except DROIDMOTE! i have server installed on the UG802 client on my GNex and even tried on my wifes LG Optimus 2X but nothing works... i searched with root browser for uinput and it didnt find anything.. any ideas?
          BootLoop
          Never got this ROM to work, only BootLooping...
          any idea, how to fix this ?!
          I go to flash mode by shorting the pads near NAND chip.. does that affect anything ?
            Hey guys, I made a NEW post for 2dark4u ROM and moved some posts from here to the new thread.
            Move the convo there plaase to make it simple for people to find.
              Originally posted by krizz07 View Post
              did you extract the contents of the zip file to the root of your sdcard?
              Yes. Going from stock to 1.4 was no problem. Now nothing happens. Tried restart and ntfs and fat32
                Mine didnt update from card, it worked only from internal memory
                Same kriss as on FMA
                  Play Store
                  Went from easy 1.4 to 1.4a and play store never worked. so now went to hard way 1.4a. And play store still doesnt work. I am signed into gmail and the accounts for play store. Also clicked on over wifi only just in case under play store settings. am i missing something? I know the hard way worked becaused it cleared things out(i intentionally left stuff so i would know if flash hard way worked). It just says "Downloading" but its been awhile and i think its going to time out and not do anything. Any thoughts?
                    Booting Linux from SD Card
                    Hi Bod, Great Work! I have one request. Is it possible to look for the boot files in the SD card first? I think MK 802(first version) does this way. If found boot from SD card or else boot normally in android. That way we can actually try different variants of Linux from SD card or even windows 8 in the future.
                      I have a problem playing games with 1.4a (I did not test with 1.4) anyway. Download for example rovios 'bad piggies'. The game starts but it's not possible to press any of the buttons within the game. The game sprinkle has the same problem.
                      Anyone or all having this problem?
                      Thanks for helping and thanks for a great rom.
                      /N
                        status bar
                        I have a small prbl. When watching some tv online the status bar covers the bottom of the picture. Is it possible to have a setting like auto hide?
                        I've installed the 1.4a. I am testing it now. Excellent job Bob. Thank you
                          Where do you put the update.img locally? Tried the download folder but nothing is detected.
                            All the instructions are in the readme in the ROM download!!!!!
                              Play Store
                              Still cannot get it to work. Is just froze on "Downloading". I have gmail account and on, gmail works. I also created a new account to see if that would help. Deleted old account. Because even after selecting new account it still wanted to download on old one. Got that cleared to download under new account, cleared data and cache to all google play apps. still no go. confirmed also finles 1.4a, also confirmed with market enabler number is 310260, and bob changed .jar in 1.4a..sooo, Any thoughts which may cure appreciated, getting tire of swapping sdcard to download apk's.
                                If you get an market error, try to change your account from [email protected] to [email protected], this fix worked on my side.
