UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
    I think you'll have to shorten the Pins and then plug in the Micro-Usb and it will boot into Flash-Mode
      Originally posted by henry View Post
      Thanks for help ,
      I tryed this several times ,but just for shore?
      plug in the mini usb?
      shorten the pins for how long?
      Are there other way's too reset?
      Still have in4dealz.com logo, freaktab below and a fineless root on the bottom right corner
      for me it took me a couple of tries... you need to plug it in while it's shorted - you'll hear windows bing sound and you'll know you're good.
        I'm trying this for the first time. I couldn't get the PC update to work, so went for the SD card method, but now it just hangs at the boot screen similar to mentioned above.
        I opened it up, shorted the pins, installed the driver and started up the batch tool, this all seemed to go ok. but when I try to "Upgrade" or "Restore" I get:
        I did notice that the support chip says RK29, but in device manager it is listed as an RK30. Any ideas?
        Cheers,
        Chris
          Originally posted by shadower555 View Post
          now it doesnt boot anymore. and i tried the open up and short but got no response
          me too
            Greeting
            I asked the dealer to replace the unit because of problems with Wifi.
            He sent me a link to that flash UG802 update.img. (Change the name to the Update.img and flasha from tf) Manual .
            Does anyone have the knowledge to check what it was, the whole ROM or just an update to Wifi
              Originally posted by Banx View Post
              Greeting
              It looks like a full rom by the size, can you mirror-it so we can check-it?
              Cant download from qq
              Same kriss as on FMA
                  It looks like the ibex ug802+ elite firmware posted here:
                  http://www.armtvtech.com/armtvtechfo...c.php?f=12&t=7 same signature in buildprop.
                  Kernel version
                  3.0.8+
                  hushishuai@test-desktop #39
                  SMP PREEMPT Fri Spe 14 15:08:46 CST 2012
                  Build number
                  rk30_box_ics_v2.0.120719
                  rk30sdk-eng 4.0.4 IMM76D eng.hushishuai.20120914.144407 test-keys
                    why
                      Boot Logo (not boot animation)
                      Congratulations for this post.
                      It is very useful, and the rom works perfectly.
                      Now I only need to change the boot logo, not boot animation.
                      Can you help me with that?
                      Best regards,
                      Filipe Pinho
                        I feckin' love these android devices. Bought two 7" tablets on the back of using the UG802 but I had to laugh when I saw 'elite firmware' in a sentence with the UG802. Finless's ROM is the best out there but I'd be surprised if it came with a working 'standard firmware'.
                          hi,
                          does anyone else having a problem with the play store access??
                          I installed finless rom 1.4, everything working great (some audio sync problems) except, i can't access to the play store, i did it the first time i installed finless rom but now it seems like it doesn't work.
                          Any help?
                            So another flash and stuck at bootloader screen here. On to a machine received today. I will look back through the thread for an answer. updated by SD method. Cant be seen on the system.
                            Regards.
                            Matt.
                              still booting
                              i flashed using the memory card and now it would not go pass the boot screen
                              can anybody help me?
                                Originally posted by froen0815 View Post
                                @Henry
                                as i read, you have to shorten the Pins and then you'll have to plug in the Device, so it'll start in Flash-Mode.
                                hope it works
                                which pins
