they just dont understand , if it was shoes or handbag iam sure it would be different (does that sound a bit sexist)
UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
Originally posted by userx View PostStock with root and play store fixed added...
unrar/uncompress and put update.img file on SD card
Originally posted by japspartan View PostDoes this work with the Finless ROM 1.4 or is it something completely different? I used the Finless ROM but it did not fix Play Store, I still get the China Mobile message.
Here is the link if you would like to know more about it.
It will erase your current ROM totally. And it will fix the china location bug.
Only use it if you know what you are doing.
The devs are not responsible for any dead devices or mistakes made.
You can brick you device if your do not know what you are doing.
My post was made to pass on user information to the community.
UPDATE 10/27/2012
UPDATE 10/27/2012!!!!
I have updated my 1.4 ROM to 1.4a and put in some fixes people wanted. Everything in 1.4a is tha same as 1.4 but with these changes:
1) China mobile framework.jar FIX for full Play store.
Special Thanks to Deadhp1 from for this fix!:
2) I removed any flash player! You can now install whatever version you want easily!
3) All APPS updated to latest versions (includes Youtube that works).
You will not need to update anything in the play store as of this date 10/27
4) I added init.d support to this ROM. If you don;t know what that is, ignore it.
If you do know what that is you will now be able to run startup scripts like V6 Super Charger
or even make your own!
5) Loader is updated to 1.16. If using the "hard way" flash tool, do not uncheck that.
Easy way update.img will install the new loader for you.
The links in the FIRST POST of this thread have been updated to 1.4a. Just redownload them.
Enjoy the update!
14b
did you get a change to look into my wired ethernet problem of only connecting at 10 meg
Enjoy the update!
I cant fix the ehternet at 10meg. I am not sure where that is even set as I have never messed in that area of a ROM yet. Any ideas I can try.
tun.ko
I think you sent me this before but I cant seem to find it. Do you have a working tun.ko for ICS kernel?
If so I can quickly update this to 1.4b
updated to 1.4a - Play confirmed fixed!
fabulous Bob! - thanks so much: shame we cant get droidmote server operational (sans payment...).
not tested audio yet (wife's got X 'crement Factor on so TV is "unavailable") - will test tomorrow:
again - thank you!!
PS - forgive if this is a repeat - but is Bluetooth fixed? hoping to sync up a Wiimote and MD EMU :P
I never really had any serious trouble with audio video sync (setting the CPU to maximum performance in antutu always seems to do the trick no matter what ROM I use), but the wifi drivers are a bit flaky in this ROM and in the stock ROM (random stutters and pauses even though the bars are full). The wifi on the 1.5 beta ROM was much better though - not a single hiccup. Any chance we can get the wifi from 1.5 (with bluetooth support mayhaps?) in a next ROM?
thanks
shame the ifconfig dont work probley then i could set it they
Originally posted by Finless View PostI cant fix the ehternet at 10meg. I am not sure where that is even set as I have never messed in that area of a ROM yet. Any ideas I can try.
tun.ko
Simple method for 1.4 to 1.4a upgrade?
Apologies if this has been asked before......the pc flash to get the 1gb app space.....my assumption based on my other devices is that this is a one time flash requirement and if we did it to get the 1gb app space then we should be able to use the "simple" update.img method to go from 1.4 to 1.4a without need for a pc....can anyone confirm that?
Originally posted by famewolf View PostApologies if this has been asked before......the pc flash to get the 1gb app space.....my assumption based on my other devices is that this is a one time flash requirement and if we did it to get the 1gb app space then we should be able to use the "simple" update.img method to go from 1.4 to 1.4a without need for a pc....can anyone confirm that?
There are currently 1504 users online. 1 members and 1503 guests.
