UPDATE 10_27! - ug802 Android mini PC TV Player - Finless ROM 1.4a Custom ROM
great job Bob!!! it works much smoother than the factory firmware also i havent plugged my logitech controller in yet as i think thats what made my mouse and keyboard act F***ed even after unplugging it and unplug reboot? this firmware update did the trick and i will test logitech controller tomorrow! wireless seems much smoother too i can click on every filmontv app station and they load up right away and with stock firmware it dragged and flashed and reloaded the app over and over same with browser and firefox!Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
fixed A/V issue
Ok guys I have a good news for you,
2dark4u says he fixed audio video sync issue for good. in online streaming and in mx player also.
he wrote that he is going to make a rom based on finless 1.4a so today or tomorrow he will release his rom, here is the original post and google translation of his post...
Господа, хорошие новости !
Мне удалось полностью побороть синхронизацию видео и звука, для этого пришлось в прошивке боба заменить всего то 200 файлов
Тестировал на Youtube HD и online видео сервисах.
Даже аппаратное декодирование онлайн потока в MX Player заработало, завтра сделаю прошивку на базе finless 1.4a.
Gentlemen, good news!
I was able to completely overcome the synchronization of video and sound, it had to be replaced in the firmware 200 files
Tested it on Youtube HD and online video service.
Even hardware decoding online stream MX Player to work, tomorrow I will do the firmware based finless 1.4a.
Originally posted by bmn View Postselam eccomania
you know the forum name? Please tell it.
thanks dude
but the firmware is not out yet. Be patient
So I am at my xubuntu linux machine at work, and unfortunately the device is not showing up in adb. I haven't done adb stuff for a while. do I need to have it "Connected to the PC"? And also, the MK802iii does not have a reset switch. Can I have it reboot into recovery once I get ADB running?
Originally posted by Runner68 View PostU try off the ug802 power then on back, it work for me.
It happen more or less one time every 15/20 power on....
Can't tell if it was the same with stock firmware, I flashed my UG802 with Finless' ROM after having powered on only one time with original FW.
Sources:
http://4pda.ru/forum/index.php?showt...#entry16643136
http://www.ex.ua/view_storage/414325789771
Here is a test version of the firmware for the UG802:
flash like finless
1. At the first start to flicker, change the resolution settings or move the slider scale, flicker disappears and will not appear again.
2. When switching resolution UG_Fixer, resets the scale, is treated as the initial boot shaky slider scale (fixed soon).
3. UG_Fixer immediately present in the firmware.
4. All tweaks of UG_fixer already applied initially, the program needs to 1360h768 and change DPI, all the checkboxes can be removed. (Functional extended)
5. replaced all the drivers and modules (everything that lay outside the core, the core remains the native).
6. Fixed problem with synchronization VIDEO / AUDIO (hard test).
7. replacing all of the codecs.
8. Many modifications of different hardware configuration (hard test what works.)
9. Test the USB webcam work, my work better, but at 2x the image sideways. Trial firmware for UG802 from 2Dark essentially got a different firmware, but: Firmware based on Finless 1.4a by Bob and mention it I can not just leave it bottle logo, replaced only bottles animation, where it is clear that the firmware is based on his work.
Firmware for UG802 with Sync Repair video / audio, and lots of goodies
18:09, 30 October 2012 , 20:49, 30 October 2012
Firmware based on Finless 1.4a from Bob
Files:
Amount: 1, Total Size: 177,271,454
There are currently 4142 users online. 0 members and 4142 guests.
