Any information about this? Changelog or anything...
Cube Talk 9x (U65GT) chinese link to V2.0 ROM
simexi,
this is the THIRD time I'm writing about rom U65GT_V2.0_update_aatt_20141215.zip: LEAVE IT ALONE!
It is a CUSTOM ROM and is very different wrt stock one, it is still based on 20141111.
I have had many issues using it...if you appreciate my efforts this is the link for any donation:
to restore touchscreen functionality on some black model when installed rom v2.0if you appreciate my efforts this is the link for any donation:
Two repair roms?
Originally posted by giouncino View Postto restore touchscreen functionality on some black model when installed rom v2.0
EDIT: Can you flash the U65GT_V2.0-TP-BACK_aatt_20141115 rom via stock recovery and the other one have to be flashed via SP Flash Tool? Are they both V1.8 firmwares?
Originally posted by 00feichti View Postis it possible to port the touch driver form the 1.8 rom to the 2 rom? for the user bevor serial:1426xxxxx?Last edited by Vohukain; 19 January 2015, 20:07.
I want to install the ROM "U65GT_V2.0_update_aatt_20141115"
I tried with TWRP recovery but it's failed.
Originally posted by tonas View PostI want to install the ROM "U65GT_V2.0_update_aatt_20141115"
Stock recovery
Originally posted by giouncino View Post...2 - rename the ROM_2.0 file in update.zip and put in root folder of microSD card, update must be performed via the relevant option in: settings->tablet information->system updates (no data will be deleted)...
...I suggest you to perform a complete backup with TWRP on external microSD before flashing, just to avoid and possible problem...
I tried with TWRP recovery but it's failed.if you appreciate my efforts this is the link for any donation:
Originally posted by Vohukain View PostWhat is the difference between "U65GT_V2.0-TP-BACK_aatt_20141115" (links: yadi.sk, mmnt.net) and the other one touch screen repair rom (which can be found from here: drive.google.com, pan.paidu.com password: dz7l)?
What do you actually need from V2.0? Lepi already ported gestures from V2.0 to V1.8.
The TP-BACK cannot be flashed with stock Recovery but only from a PC. Both are 1.8 FW.if you appreciate my efforts this is the link for any donation:
Patch does not work well with Lepi 2.0.9
Originally posted by Lepi View PostHello, my friends. At the request of giouncino I made a patch for the firmware version 2.0, which reduces manual brightness, reduces Auto Brightness and improves battery discharge statistics.
upd_U65GT_2_0_autobr_PwrProf.zip
Install only through modrecovery (CWM ot TWRP). There are no guarantees! pre-backup is required!
Checked user giouncino.
Statistics can only operate properly after deleting a file batterystats.bin from folder
/data/system and reboot.
I installed this patch on top of Lepi's 2.0.9 ROM, and it does not work well on my cube. (SN 1503xxx)
One of the problems is that the menu when pressing Power to shut down is gone.
The tablet does a direct shutdown, and when powering back on, it does a sort of quick boot? (Boot animation showing)
And sometimes the double tab to wake up makes the tablet reboot as well.
I flashed the 2.0.9 ROM from twrp again (no loss of apps) to get back to the stable situation I had before.
Maybe 2.0.9 does not need this patch?
Un saludo,
Satbeginner
This patch should be already included with every lepi's romif you appreciate my efforts this is the link for any donation:
There are currently 1866 users online. 0 members and 1866 guests.
