Cube Talk 9x (U65GT) chinese link to V2.0 ROM
Finally I found out how to install ver. 2. I flashed the tablet with the flash tool with the first "supposed" ver. 2 and then I upgraded through update.zip file the original ver. 2 and it's working. Now I have to find out how to get rid of all this bunch of chinese apps. At least I started learning chinese with all these
You can uninstall everything you want with titanium backup!if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostFirst of all make sure to have a WHITE tablet produced AFTER week 26 of 2014!
then:
1 - if you already have 4Gb partitioning, you DO NOT need to flash it again, but stock recovery is mandatory.
2 - rename the ROM_2.0 file in update.zip and put in root folder of microSD card, update must be performed via the relevant option in: settings->tablet information->system updates (no data will be deleted)
3 - after update, reflash TWRP recovery
4 - reboot and through Titanium backup uninstall ALL the new chinese apps (including chinese ROOTING! and wakelock chinese "FM" app)
5 - reboot into TWRP and install supersu binary
Installed on 2 different WHITE tablet produced on week 27 and 29 without any issue on touchscreen AND no IMEI has been lost.
I suggest you to perform a complete backup with TWRP on external microSD before flashing, just to avoid and possible problem...
Please where can I find the stock recovery zip file?
every 900ss rom has the stock recovery included in the packageif you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Postevery 900ss rom has the stock recovery included in the packageLast edited by 2kurupt; 07 December 2014, 13:47.
Finally, I managed to do all the right moves so I uninstalled the Chinese apps and I have only version 2. As far as I have seen though, supersports rom seems to be faster in response, especially when the tablet is sleeping. I will test it more though to see which one I will keep. Thanks giouncino for helping me!!!!
You're welcome.
I think that in terms of overall performance they are pretty the same.
The plus of the Rom 2.0 is the gesture (ex. double tap to wake up), that's why I preferred to stay with a newer release.if you appreciate my efforts this is the link for any donation:
That's exactly my problem. Gestures. For example when I double tap my tablet wakes up when it wants to. Some times it is like knocking a deaf's door. Additionaly when I type my pin too fast it zooms the screen instead of typing the pin. Probably it is my fault. I have to test it and find out.
Probably double tap to wake up works better on bottom part of the screen, but I didn't test it well to be sure.if you appreciate my efforts this is the link for any donation:
If the tablet is constant on a table or so, most of the times it responds normally if its not in deep sleep. if you move and it is not in a stable position then it never awakes. I do not know if I have to disable G sensor. Try to enter a pin number but quickly. Do not wait till the asterisk appears on the screen. When I do this mine zooms the screen.
why sdcard2??
I think that when you put the microSD it should be sdcard1!if you appreciate my efforts this is the link for any donation:
There are currently 1771 users online. 0 members and 1771 guests.
