Cube Talk 9x (U65GT) chinese link to V2.0 ROM
    Newbie orderd cube 9x and needs help with the flashing world
    Hello,
    I'm ordering a Cube 9x today.
    After doing some research I've decided it's probably the best Chinese tablet today and will get me the most value for money under 250$.
    From what I understand I should stay away from the black version, as it doesn't get the new 2.0 firmware. I'll order a white 32gb and hope it'll be week 26+.
    I really need some help getting into the whole ROM flashing business, I'm an IT professional and I know my way around software and I've been jail breaking iPhone since iPhone 3, but I never had the pleasure of flashing an android device yet.
    Is there any chance that someone like giouncino will make a newbies guide for how to get a new cube 9x from its original version to the new v2.0 with 4GB apps and without all the Chinese apps? if so, I would really appriciate it, and I bet it will be super useful to everyone visiting the forum,
    I also have some specific questions:
    1. What is stock recovery? is this a recovery mode you can boot into? if so, how?
    2. Do I need to root the device before I can update its firmware to 2.0? if so, can someone link the appropriate tool?
    3. When you say I need to rename the file to update.zap, which file is that? is it the file named U65GT_V2.0_update_aatt_20141115.zap you linked in this thread? or is it a file inside this zip?
    4. You keep talking about TWRP, do you mean TWRP manager app, or TeamWin TWRP? In http://teamw.in/twrp_view_all_devices cube 9x isn't listed, which version works with it?
    5. You said that I need to reflash TWRP recovey after the update, why is that? won't it just get the tablet to its original OS?
    6. How do I backup the original OS and system data in case something goes wrong?
    Thanks to anyone willing to help me out, I'd appriciate it if you won't send me tons of link to generic FAQs for Android flashing, since cube 9x isn't a poplar device and I'm not sure how these FAQ will be relevant.
    Thanks a lot!
      Originally posted by xfifi View Post
      I received my freshly new black 32gb u65gt tablet and i would put a custom rom. The Rom already installed seems to be a v2.0 rom (see pics) !
      Can i put your custom rom v2.0 safely ?
      This is interesting, it must mean that the new batch of tablets coming out of the factory is already updated to v2.0.
        I purchased this tablet November 19, 2014 and received yesterday.
        Ok but i want to remove these chinese apps et add apps that need to be root.
          Xfifi, you do not need to reflash the whole rom, you just need to flash TWRP recovery (lepi_2810 is perfectly working) to be able to install supersu binary, then if you want you can also flash ebr1 and ebr2 to have 4gb app space (you can get both files in any 900supersport custom rom kit)
            Giouncino : great, thank you for the information. I'll do that. Fantastic forum here !!
              files
              hey there giouncino
              where can i get the ROM and files you mentioned?also where can i get the twrp to flash after installing v2.0?
              changing to update .zip means the whole v2.0 zip file i downloaded right?
              i just don't want to mess anything up
              would appreciate any help
              cheers
                rename this file:
                MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
                to update.zip
                twrp_2810 can be found in the forum...
                seach with "TWRP_2810_LEPI_scrsht.zip"...(unzip and flash it)
                  Oops ! I tried but it misses scatter file for my stock rom. Where can i find this file ?
                    here:
                    MT6592_Android_scatter.txt
                      TWRP_2810_light_LEPI+newTheme.zip
                      videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
                      TWRP_2.8.1.0
                      TWRP_2810_newTheme TWRP_2.8.5.0
                      PayPal donate WMID410517421626
                        Tthank you for your help.
                        However, i have big problems to connect the tablet in usb. I have installed the drivers but the tablet does not recognized by win8.1 win7 64 bit and 64 bit (on other laptop). I plug usb cable and i hear the usb device recognition sound in windows and also a second sound disconnection. It alternates between the 2 status indefinitely connect / disconnect with battery charging icon showing.
                        My tablet is in developer mode with debugging enabled for usb.
                        Maybe the usb cable ? I 've tried with another usb cable and i's same issue.
                          you do not need to have debug on.
                          I have had no issues flashing the cube on windows 8.1 x64 and windows 7 x64.
                          On win 8.1 you need to disable digital signatures for drivers.
                            Battery percentage issue?
                            Thank you very much reporting testing! If I got you guys right this V2.0 IS NOT going to fix battery percentage issue?
                              Digital signatures are disabled. It's the first thing i did when i installed the drivers.
                              I don't understand why the cube want not connect correctly.
                                v2.0
                                Can I use the newtheme.zip with v2.0 rom?
