Kikat - Wasser Firmware for Beelink R89
    Hi Wasser!
    There is a bug with system sounds.
    If you set default output in settings so there is a system sound.
    If you set HDMI output explicitly then a sound disappears. No menu sound, in apps that use system sounds (Action Timer for example), talking watch. All players work fine with a sound.
      Hi!
      Is there any magic, how to get 5.1 through hdmi?
      Maybe this is possible using lollipop version ?
      -edit-
      solution found - using spmc, (from their site (v 15.0), because google play still have 13th version)
      in device settings set hdmi bitstream
      in spmc settings - hdmi passtrough
        For those of you that haven't checked out Wasser's new rom for this hardware you might want to take a look. RC4 is pretty nice. Kodi, SPMC don't have 5.1 audio passthrough working for RK but MX Player does. This rom fixes the random Android audio drop outs. 1080p Youtube works better on this rom too. In general video is smoother on this rom and doesn't seem to struggle much. There is a very noticeable video quality improvement over SPMC/Kodi when using MX Player on this new rom. http://freaktab.com/forum/tv-player-...89?view=stream
        Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
          ACE player isnt working there, so doesnt torrent tv
            In an effort to reduce the number of Kodi and SPMC crashes I reverted back to Wasser 2.0.3 and installed this Kodi 15.1 https://mega.nz/#!WxwjAZBR!KtVSfWLCP...pLL6-v442mjDGc. It has 5.1 passthrough and I don't see any micro stutters with 40GB MKV files. You can follow this thread if you want more info about the Kodi 15.1 that's linked above http://freaktab.com/forum/tv-player-...ck?view=stream
            Edit: No luck. That didn't fix my problem.
              He is responsible for what part radical_update "?
              The cooling system on Tronsmart Orion R28 Meta Wasser2.0.9a)
                adaptation for remote Tronsmart Orion R28
                kernel_tronsmart_r28_wasser2.0.9А
                http://4pda.ru/forum/index.php?s=&sh...ost&p=47971385
                https://www.youtube.com/watch?v=siRP...ature=youtu.be
                  Where can I find the source code for
                  http://www.freak-tab.de/wasser/wasser-kodi-1.0.apk ?
                  I have An AMLOGIC 8726-MX tablet, and this is the only version of kodi that does not produce a blank screen when it starts. The firmware is 4.1.1, therefore use API level 16 , and only version <=14 will work. I tested several versions including SPMC and all produced blank screen except this version. However on hdmi it produce a zoom, when AMCODEC is used issue that supposely was fixed in Isengard version.
                  Please help.
                  Thank You Very Much
                    Nobody knows where can I find location of sources for http://www.freak-tab.de/wasser/wasser-kodi-1.0.apk ?
