Kikat - Wasser Firmware for Beelink R89
    Will this rom be updated to support Kodi 15? I tried Kodi 15 RC2 and the HDMI audio passthrough produces white noise. I am using 2.0.9a with patch.
    Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
      Kodi 15 needs to be updated since it doesn't contain the code for passthrough to Rockchip devices.
      Heard SPMC was going to be merged with Kodi, so no need to use SPMC anymore on Rockchip devices.
      Using passthrough patch, libmedia.so file won't work anymore since there were too many changes the past months from Rockchip.
        Thank you mo123
          Since of now I get a "storage safe to remove" notification with the latest 2.0.9a every time I boot up.
          Looking closer it seems it NAND gets unmounted...but why...everything else works fine (All the available space in 1 partition...all apps are there and working)...its kinda just a annyoing message.
          Anybody got a clue how to get rid of that ?!?
            Can I flash the resource.img for overclock provided by wasser on my beelink r89 with the OHC rom? Or it works only on device with wasser rom?
            Because I know nothing about flashing, I'm not sure if the resource file and the rom would work separately or if I mix them would brick my device? Thanks a lot.
              You can try it.
              Can always reflash if it doesn't work.
              You can't brick RK3288 devices, there is a safety boot present called maskrom mode that kicks in if something went terribly wrong.
                You can try it.
                Thanks for your advice. I'm using OHC rom with OHC over clock kernel and resource 1800. When I tried wasser over clock resource it's ok but i can't see any improvement during video playback. when i flash the boot.img as well it hangs and i ended up flashing the whole firmware again lol.
                Does flashing resource alone enough for overclocking cpu ddr and gpu?
                  Yes
                  But not for CPU, if you want 1.8Ghz, you need to unlock it in the kernel with Overclockomatic 1.06
                    Hi Wasser,
                    My issue is flickering screen on streaming video, does Firmware 2.0.9a fix this problem?? Or i have to flash Lollipop version 3.0.0 beta6 ??
                    i wanna try your firmware 2.0.9a for my R89, can u please teach me how to flash this device? thank you.
                      I have a question on system space :
                      In settings storage I have 2 partitions:
                      -Internal system
                      this one is 2GB and near full (containing everything, apps, documents ..)
                      -NAND Flash
                      11.3GB near empty !
                      how to use Nand Flash for application ? /sdcard ?
                      I didn't see an option to move app on sdcard (in system/applications)
                      Regards
                        Originally posted by Kytrix View Post
                        -Internal system
                        -NAND Flash
                        11.3GB near empty !
                        Regards
                        Wassers ROM's normally come with a single unified storage partition, utilising all of the available space.
                        What ROM version are you using?
                          I Use wasser ... but maybe my flashing was not good :/
                          I use this steps : http://freaktab.com/forum/tv-player-...r89-from-linux
                          I use rom waser 2.09
                          Is it possible to merge the 2 partitions after ?
                          .. I can test with Wasser 3 rom ..
                            I see you are coming from Linux, not Windows.
                            Never used Linux to flash before, so can't comment on that side of things I'm afraid.
                              I just restart in bootloader .. it's not very usefull :/ can't do a backup with it.
                                just flashed on my R28 orion, amazing rom !! thank you
