Kikat - Wasser Firmware for Beelink R89
You have to install a custom codec for MXPLayer to use AC3 codec.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by mo123 View PostYou have to install a custom codec for MXPLayer to use AC3 codec.Originally posted by clarkss12 View PostOk, thanks MO, strange that I have never had to do that on any of my other roms or devices....
Originally posted by hellomysons View PostAfter using the new 2.0.9a rom , i have a problem with the display resolution in HDMI (1080p/60hz),
the box display area is over my tv screen and cause something hidden or show incomplete ,
RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View Post
When hardware can decode audio stream then it isn't necessary. It was like that in first RK3288 ROMs and it just came back with newest firmwares like Wasser's 2.0.9.
my box is beelink u89 , what can i do to solve this problem , thanks.
Originally posted by bloodgnome View PostI have to correct myself. After a couple of days without the audio mute bug it happend today 3 times during the latest episode of game of thrones. really annoying.
@wasser... I can provide another log if you need?
Originally posted by claudecir View PostHi,
I Have added the file of oc on microsd and applied in recovery boot, but the beelink rk3288 not boot stoping in wasser name on start boot, what i do to return to 2.0.9a?
Sory for my bad english.
If you really get stuck and can't get it back into flash mode which my video https://www.youtube.com/watch?v=K9lLJirKEIQ
Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Wasser
Could you please check out this rom http://freaktab.com/forum/tv-player-...326#post499326
It think it has perfect playback so maybe you can use/alter some files from that rom and add it on your rom for even better playback?
Thanks!
Originally posted by roolmapool View Post
yep... it happen a lot with last version.
Thanks!
for Example:- AC3 format can not be played
- video stutter
- google play movie doesn't work
- google play music silent issue
- and more ....
What i really like to hear and comments what is better in this firmware and what work in this fw and not work in my firmware. Such feedbacks are important for me to improve the FW. Does the The random audio mute issue appear in this rom?
It doesn't help me if just only tell me it has perfect playback!
I really want to fix the random audio mute issue, but somehow i really cannot reproduce this issue. Without a reproduceable testcase it's not possible to debug and fix it!
So please try to find a reproduceable testcase so i can reproduce it!
Originally posted by wasser View Post
yes, please send me a log files and please give more infos about your settings, which spmc/xbmc version you used
I use 2.09a firmware, OC kernel, standard HMDI sound, SPMC 14.2, tronsmart TS1 flymouse.
Mute issue comes a lot with last firmware....
i'm not sure why this rom has perfect playback. I played around with this firmware and found a lot of issues in playback.
- video stutter
- and more ....
You're right my bad.
I only tested in SPMC.
What i'm seeing in chameleon firmware is a smoother framerate / less judder (not stutter) in SPMC, especially in panning scenes. In your rom i see some minimal judder in panning scenes.
I do not have to use the option "adjust display refresh rate"and "sync to display". I need to enable this in your rom. Not really a problem, but it is a difference. I'd rather keep it off.
As of hw acceleration, in your rom for best playback i use libstagefright OR mediacodec. RKlibstagefright causes artifacts.
In chameleon i can keep RKlibstagefright, libstagefright and mediacodec enabled without problems.
I did not see the random audio mute issue yet on this rom. If i see it i will report.
There are some programs like volume lock that keep the audio at 100 procent at all times, maybe you can implement that as a workaround? You will see the volume slider indicator though when it tries to mute, but i think that is hideable too.
I hope this helps a little more.
Thanks.
There are currently 3056 users online. 1 members and 3055 guests.
