Kikat - Wasser Firmware for Beelink R89
Originally posted by wasser View PostRK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by torbvea View PostWhy can't I use OC on my box? The box freeze at the boot screen when I tried to use overclockmatic also.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Also are you using a 3A power adapter? Lower ones don't have enough power for overclock and might run unstable.
Hi all,
i uploaded beelink-r89-sound-fix.zip. User who has sound issue please update it and report the results to me!
Wasser
Do you have a heatsink or extra cooling?
WasserMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Wasser
-AaronTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Wasser Firmware 2.0.9a for Beelink R89 is released. For more infos please take a look at the first post!
Please report the feedbacks, it's very important for me to improve the firmware!
Enjoy!
Wasser
DTS and DD passthrough seem to work just fine on Yamaha AV Receiver with HDMI audio output with SPMC 14.2. Stereo apps work just fine as well on my Tronsmart. I've set up the audio to play stereo all night. I'll see if it will auto mute tomorrow and report back. I'll also see how well it does with Pioneer AV Receivers too.
Originally posted by amclean123 View PostIs this sound fix zip to be applied on top of 2.0.9a?
-Aaron
I installed your newest rom version 2.0.9a yesterday on my Beelink R89, 8 gig version, had been running linux on it. Been a long time since I had last used one of your roms, but this one is almost perfect. It has Dolby and DTS passthrough using the latest Kodi 15 nightly, which is awesome. One problem I have encountered is in the audio track using Kodi, I have a hick up in the audio every three seconds. Not sure if this is the sound issue that others have reported, but I just installed your sound-fix zip, but it did not solve my hickup problem. Everything else seems to be working great for me, camera, contacts, calendar, all work. thanks
Plesse send me the log files so i can take a look, and log file from Kodi too.
thanks
Originally posted by wasser View PostDoess this issue happen in other apps like mxplayer?
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by wasser View PostYesLast edited by amclean123; 29 May 2015, 23:36.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
There are currently 2842 users online. 0 members and 2842 guests.
