Kikat - Wasser Firmware for Beelink R89
Originally posted by eebrains View PostI'm very excited to try the 2.0.9a - but when i download the 7z file it can't be opened with windows 7-zip? I've not had trouble with extracting the files before... Not sure what i'm doing wrong.
Originally posted by wasser View PostHi all,
i uploaded OC kernel update-cpu1920-ddr700-gpu625.zip . Please rename it to update.zip, copy it into /sdcard, and reboot device.
Enjoy,
Wasser
i only use 7z to compress under linux and i dont have any problem to extract it with 7z under linux.
Thanks Wasser! it worked now. For some reason chrome thought the file was only 122 MB and so it was clearly corrupted. After cleaning my recycle bin and restarting chrome, it downloaded correctly.
no, it works for me. please goto Settings->Storage->Umount USB Storage NUMBER.
i cannot reproduce this issue.
That route does work but the one that I use is by dragging the bar down from the home screen and ejecting from there.
At least I know that one method will work, which is fine for me thanks.
Originally posted by BTR11 View Post
This download link it´s not working or report as "page not found".
Originally posted by torbvea View PostIs someone else having problems with the OC kernel? After I installed it, the tvbox will just freeze on the bootscreen.
Wasser, i flashed v2.09a (last one) and OC kernel, but i the "random mute' is always present (more than previous version, IMO)... do you need a log or something?Last edited by roolmapool; 27 May 2015, 08:50.
@wasser
Hi wasser,
maybe you should also link to http://freaktab.com/forum/tv-player-...-get-a-logfile at your OP (maybe at the latest version) to get log files?
RK3288 Devices
- Overview BOX (LINK !)
I'm using 2.0.9a on the first Beta-Tester Box from Beelink/Oman and with the Google Now Launcher.
So far 2.0.9a runs great an *knocksonwood no Audio-Mute Bug.
But I found another bug (i think): Using Google Now Launcher it doesn't recognize the "OK Google" command. So either something is missing in the new Firmware or the Mic isn't activated somehow. Could someone with the old Beta-Tester Devices test this on their machine.
Or maybe i deleted something by accident...
Originally posted by roolmapool View Post
It s OK for me.
Wasser
Originally posted by mghb View PostHi Wasser.
after I've installed 2.09a some regression is back.with Mx player hardware switch on sw that I've not this problem with 2.08(when I play dts and dd movie).I have av recieve teac ag-d500.my sound is hdmi bitstream.
Originally posted by no_spam_for_me View Post@wasser
Hi wasser,
There are currently 2956 users online. 1 members and 2955 guests.
