Kikat - Wasser Firmware for Beelink R89
Originally posted by bloodgnome View Post
Why ?
The Audio-Mute bug seems to be gone. I watched for 4-5 hours and left the box on overnight...so far it didn't mute.
All the Streaming Apps i tested (Stream Box, Videomix, ect.) work fine. SPMC works fine but still the occasional micro-stutter like with the past Versions. All other Apps work fine too.
Originally posted by bloodgnome View PostFor me its the best Firmware for now. Still I hope that Rockchip gets up from their lazy butts and fixes the remaining Problems with a new SDK.
EDIT:
After all the testing without the bug yesterday i got the audio bug twice today. Im sure wasser will fix it in some future version though.
But Wasser your dedication it´s admirable, specially considering that this device looks like had been forgotten or abandoned from the manufacturer in a very short time.
In my concept the worse of the bad symptoms of the R-89 it´s the never been solved the systems micro-freezes leading the micro-stutters of the Kodi or SPMC, or some other tasks.
Thanks wasser for giving us hopes on this device on the base of your firmwares development, and not get yet the conclusión that this device had unsolvable hardware deficiencies.
I really had a bad taste for rockchip after being burned with several of their 3188T devices. I SWORE that I would NEVER purchase another device with a Rockchip CPU. Anyway, Oman from BeeLink honored me by giving me one of the R89 test boxes. In the beginning that box had severe problems, but he was always there to help resolve those issues that his resources allowed him to do. However, it is my understanding that Rockchip stopped the debugging on there end, so now that box is about 90% to 95% complete, and will always be that way. I have tried most of the firmwares posted on these forums, but none of them have solved all the problems, and probably never will. I do appreciate all the work that the devs have put into solving these problems.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by bloodgnome View PostToday I got two crashes while watching Magine (A Stream TV App for German TV). Never had a crash with 2.0.7....
Why ?
EDIT:
Does this bug happen in my previous firmware? if not which Firmware version?
It's really strange that i cannot reproduce it
Wasser
Noob question, if you are on an earlier version of the ROM can you update to the latest version or do you need to do a clean install? If you can update, what are the steps? If you can't update, are people just relying on Titanium Backup to restore their apps/settings after a clean install or is there another option?
Thanks,
slyger
Originally posted by slyger View PostNoob question, if you are on an earlier version of the ROM can you update to the latest version or do you need to do a clean install? If you can update, what are the steps? If you can't update, are people just relying on Titanium Backup to restore their apps/settings after a clean install or is there another option?
Thanks,
slyger
You do have to carry out a clean install.
Restoring Titanium backups does the trick for me.
Originally posted by wasser View Post
could someone please give me a simple testcase how i can always reproduce the audio-mute bug?
Wasser
Open Youtube and play a stereo video . Don't stop or pause it
Right click on a mouse to exit Youtube while the video is still playing.
Open SPMC with passthrough correctly set up
Play a DTS MKV video. Make sure that your receiver detects the 5.1 DTS audio
Let this play for an hour
Pause it
Wait an hour (If an hour doesn't work let it sit overnight)
Right click on the mouse to exit or swipe up with the mouse and hit home
Go back to Youtube and the audio will be muted since Youtube doesn't use passthrough.
Unfortunately all of your roms have had the muting issue on stereo audio feeds. The muting doesn't affect the 5.1 DTS passthrough audio HDMI bitstream in SPMC or MX Player. The muting only affects stereo audio like Youtube, Pandora, Vevo, iHeartRadio, PBS kids, Youtube Kids...
I was also able to reproduce this with SPIDF passthrough too. FYI when I use SPIDF or HDMI bitstream audio output none of the normal Android OS beeps and sounds ever heard. I doesn't bother me but just an observation.
I haven't tried yet to replicate the muting issue with my R28 hooked directly to my TV via HDMI or SPIDF. I've always used a Yamaha or Pioneer AV receiver.
I don't know if this helps but when the RK3188 roms had a similar muting issue some fix was made to allow the default output to handle HDMI bitstream.. You had to know to pick the default output and not choose HDMI bitstream.Last edited by amclean123; 18 April 2015, 05:54.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by amclean123 View PostThe easiest way to replicate is to use HDMI bitstream output using an AV receiver.
Pause it
Thanks,
Wasser
Firstly, many thanks to Wasser for his continued efforts - much appreciated.
My Tronsmart R28 Orion is connected to my TVs by HDMI - no AV receiver. I am also getting the random mutes after the update to v2.0.8 when streaming content through SPMC 14.2. In addition, I now get no sound when the box is connected to one TV (Sony KDL46X2000) but the sound is fine when connected to my other TV (Sony KDL22E5300). Looking at the specs for the two TVs, the only difference I can see is that the KDL22E5300 (which is newer) has 1080/24p (as well as 1080p) whereas the KDL46X2000 has 1080p only. The video / sounds settings on my R28 are all auto. I've tried different cables, changing the HDMI input socket etc. none of which measures have had any effect.
I'd stress this is not a big deal but thought I'd share on the off chance that either someone has a fix or it might help to narrow down what is causing the muting bug.Last edited by ManxYessir; 18 April 2015, 09:03. Reason: Oops - posted by accident before finishing the post!
Sadly i don't have any AV receiver at home. could it be that this issue only appears by using ac receiver? I really want to fix anoying issue, but i need a simple testcase which allows me to reproduce this issue!
Thanks,
Wasser
Is it some way I can help by recording a log?
Do you think you can fix the download link for the new v2.0.8. Really want to test if the audio dropout is fixed when using HDMI Passthrough now! Thanks for all the hard work.
There are currently 1972 users online. 0 members and 1972 guests.
