Kikat - Wasser Firmware for Beelink R89
Random mutes or noise
I also verify random mute especially after youtube installation.
I usually had in android mute and in SPMC HDMI pass-through without any problem.
Since i installed youtube app when i'm in SPMC with DTS (pass-through) movie then suddenly the sound either stops or makes white noise and then recovers (in a movie of 2 hours it did it 5 times).
After a week, the random muting happend twice last night. This is through HDMI, no pass through just the basic hdmi to tv setup.
The random mutes are very rare, but when it does happen, it happens 2-3 times in succession. This is really the only thing that bugs me with this rom. I'll install logcat and if it happens again. Hopefully the issue can be tracked.
Thanks Wasser in advance for your never ending efforts.....
my only concerns before flashing with your latest rom on my R89 are two thanks :
- will i be able to shutdown device normally like that in the stock rom (instead of the chronic reboot issue ?)
- if i'm only using Mx player as a media player (i mean , not using SPMC at all) , will i get dts and dolby via SPDIF PASSTHROUGH setting with optical cable to my harman kardon receiver....?
God bless you all
I am almost sure that my WIFI improved by installing the 2.7 from the stock 111k4, and for that I thank you Wasser, but I cannot figure out how to get the on-screen keyboard to come out, normally I click on the space requiring typing and the keyboard shows up, Also I miss the Stock Oman light launcher, anyway of downloading it on its own.
Originally posted by minonano View PostI am almost sure that my WIFI improved by installing the 2.7 from the stock 111k4, and for that I thank you Wasser, but I cannot figure out how to get the on-screen keyboard to come out, normally I click on the space requiring typing and the keyboard shows up, Also I miss the Stock Oman light launcher, anyway of downloading it on its own.
You turn off the hardware keyboard in settings, language and input.
after installing Wasser 2.0.7 i have the problem that the beelink hangs sometimes for ca. 30sec
First time was in ESExplorer and the second time was in titanium backup when selecting apps to restore
before i had 2.0.3 and that worked with some micro stuttering in video playback
i have no logcat when it hanged but when i lock now into logcat i see often:
E/Lights ( 466): write_int failed to open /sys/class/backlight/rk28_bl/brightness
or when using amazon instant video:
E/ion ( 1109): ioctl ION_IOC_ALLOC(c0144900) failed with code -1: No such device
D/gralloc ( 1109): Force to VMALLOC sucess !
W/gralloc ( 1109): Debugmem The fd=332, in vmalloc !!!! Ishwc=0
W/gralloc ( 1109): Debugmem The fd=333, in vmalloc !!!! Ishwc=0
is it normal ?
Using SPMC 15.1 i have different audio muting sometimes and some switching between stereo and DTS on my Pioneer AV-Receiver when using passthrough.
has someone the same problem ?
so i have to add some more info:
today evening i restored wasser 2.0.3 with twrp backup (there was no kernel restored) so i think i was running my old wasser2.0.3 with 2.0.7 kernel
and with old working spmc 13.4 (i think it was 13.4) and i had a sound crash after nearly 10 min watching movie
my pioneer av-receiver displayed stereo instead of DTS before and there was that noisy sound when hearing DTS bitstream @ stereo
after disabling and enabling passthrough in spmc the sound never crashed in the following about 2:30h of the movie and stayed DTS.
so today i installed Wasser2.0.3 with AndroidTool_Release_v2.3 fresh but the same behave like after restored 2.0.3 with twrp
Sound crashes but never did on 2.0.3 before
What is changed when updating to 2.0.7 and downgrading to 2.0.3 ?Last edited by FunThomas; 03 April 2015, 10:39.
Does anybody else have issues with SPMC 14.1-14.2 forcing their TV into 720p every time its launched? This started with Wasser 2.0.7. I have to go back to settings select the desired resolution again. Doesn't happen with Kodi 15 alpha.
Update: This only happens when the system is set at 2160p30, when on 1080p it stays that way in SPMC as well.
i can confirm that the audio muting with wassser 2.0.7 problem here is simply switching to stereo and sometimes back to dolby digital (then its louder again)
i dont know why it switches to stereo and somtimes back
but sometimes it also switches to the stereo bitstream noise
2 times in the first hours the wasser 2.0.7 was frozen and nothing happend in the 2 minutes after
the first time when copying files from external to internal sd card and the second when selecting video in SPMC
But now it worked since 3:30 h without freezing the complete image
Freezes seems to be gone even after restarting and the audio problems seem to occur only one time after rebooting and after it happen -> switching passtrough in SPMC 14.2 off and then on again it works like a charm
Dont tried yet to switch passthrough off and on without the problemif the problem occurs but will do next days
Hi Wasser,
thnaks for the 2.0.7 fw!
My Ubox is perfect, I used the latest beta SPMC ,and the movie playback is very smooth,no more video shutter,and lag
I play the movies from SMB share with 5Ghz wifi,and no problem.
Skype working with the Logitech C310 webcam (audio-video) , BT Ipega gamepad working,and finally Youtube in 1080p
a question:
1920x1080x120Hz is possible in Android?
The 120Hz is necessary to the DLP Link 3D capable projectors.
http://en.wikipedia.org/wiki/Active_..._system#DLP_3D
T-R42 v1.0 ; Ubox R89
There are currently 3069 users online. 0 members and 3069 guests.
