Kikat - Wasser Firmware for Beelink R89
Originally posted by rock-star_79 View PostFirst I want to say thanks for this awesome rom. I now have close to no video stutters. Watching videos on my Tronsmart r28 was almost unbearable to the point I almost gave up on this device. I do however still have buffering issues. Almost every movie or show that I watch take 5 to 10 minutes to completly buffer. I had it with the stock rom and still with this one.
I thought it was my network but I have kodi installed on the Galaxy Note 3 and it play the same movies and shows and i have little to no buffering. Any idea what could be the issue? I am using SPMC 14.1 and I created an advancedsettings file like the one posted a few post backs but that only allowed the buffering to complete. I did a couple of test on speedtest.net and my download speed is at 21 to 23 mbts and upload speed at 1.5 to 2 mbts. Any help would be appreciated. Again thanks for the hard work.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by amclean123 View PostAre you using wireless? If so, try wired. Plug a hard drive into the Tronsmart r28 and watch them local and see if you have the problem. I have 4 Tronsmart r28's and they all work great on wired. I'm streaming 35GB files wired with no buffering. Make sure you're using Wasser 2.0.7. Remove your advancedSettings.xml. It's not needed for a wired connection. It can't accurately buffer all movies over wifi well. Some movies it will try to buffer for 10min.
Originally posted by rock-star_79 View PostIm currently using wifi and wasser 2.0.7. Ive tried both but same results. Plus im able to stream Netlix, Hulu, and Youtube on wifi with almost no buffering. It just SPMC, or even XBMC that have the buffering issue. Thanks.
You can dowload the MX Player 5.1 codec here. Just put the entire zip file in your Android download folder and open MX Player. MX Player will import it correctly.
In the upper right hand corner of a playing movie you'll see if MX is using HW or SW (software) to decode your movie. In the settings you can choose from SW HW or HW+. That may help your buffering issues. The default MX settings work fine for me.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by Oleg.Log View Post2.0.7 don't execute script from /system/etc/init.d, manually run script ok. On 2.0.6 and lower firmware script work fine.
Originally posted by sawbones999 View PostI'm pretty sure one of the folders for SPMC also has a leading "." - a.k.a. it's hidden and you won't see it in something like ES File Explorer unless you have hidden files enabled under tools. It used to be .xbmc but it may have changed between Gotham and Helix.
Cheers all!
-SB
Yes as you can see in kodi path I insert the .kodi
For SPMC the correct one is /sdcard/Android/data/com.semperpax.spmc/files/.spmc/userdata
In some movies that have big bit-rate you can experience some buffering.
For example when I stream over Internet where usually the bit-rates are low i do not have any buffering issues but when i stream from my NAS a movie with high bit-rate then occasionally the buffering will appear.
That is why i use the advancedsettings.xml.I start the movie pause it for ~5 seconds and then let it play (the buffer is full and at the scenes that have large bit-rate the SPMC will play (consumes from buffer faster than stores in it) it without stopping for buffering).
You can observe it by pressing in your keyboard the key o or c (in the third section you will see the buffer settings) and give us an input!
I use this one https://play.google.com/store/apps/d...l.init.d&hl=en
It is working in 2.0.7
Originally posted by amclean123 View PostTry using Mx Player. It has 5.1 audio too. I use SMB Network Places (see link below) to see my videos on my LAN. Then click the video choose MX Player. It's much easier than configuring CIFS. Plus I've had better luck buffering with SMB Network Places app.
If you use the codec in H/W+ then the MX player will decode it to stereo and not pass through if you have HDMI bit-stream under audio in system settings of Android, but if you have SPDIF selected then you do not need the codecs, since the audio will passthrough SPDIF and wont be decoded in MX player as long as you have an AV receiver that can decode AC3 and DTS.
MXPlayer playercorefactory.xml
There are currently 1945 users online. 2 members and 1943 guests.
