Kikat - Wasser Firmware for Beelink R89
Originally posted by ManxYessir View PostHi Wasser - I flashed your new kernel and now have sound on my old and new TVs! Many thanks for resolving this - much appreciated.
Originally posted by Mario023 View PostThank you Wasser for your great job.
Report issue for a couple times .
Camera app it does not work properly .
Crashes when I start video recording.
I have c270 logitech cam.
Thanks.
And Plesse log files too. It helps me alot to debug/fix the issue
Originally posted by amclean123 View PostThanks Wasser. I'll download, flash and see how things look. I'll test the new SPMC beta 1 too. It was giving me problems over HDMI that SPMC 14.2 didn't have.
Feedbacks Plesse!!!
Thanks.
Thanks for your report and feedbacks!
Originally posted by rock-star_79 View PostDoes the stock remote work on this version? Also how is the youtube performance? Im on 2.0.7 and the video stutter on youtube are very constant. Every other video its very minimal except youtube.
Thanks wasser for the constant updates!
to your problem with youtube, maybe it's network issue in your setting. Please check your network route
Wasser
2.0.9a: still sound interruptions continue
2.0.3: no problem with sound. I'm use this version.
Why are there sound interruptions? What is the solution?
My device Tronsmart Orion R28 Meta.Last edited by runonur; 23 May 2015, 08:08.Tronsmart Orion R28 Meta RK3288 Wasser 2.0.3
Samsung Galaxy S4 GT-I9500 4.4.2 OzcanRom.v6.3
Originally posted by chrisarchon View PostHello.
Thank you Wasser for your great firmwares, without them I would have thrown my Tronsmart R28 out of the window.
I got an issue with the latest firmware.
I am using Plex and with the last firmware I can't direct play any video that has AC3 or DTS audio.
The plex server has to transcode the audio track. And if I force direct play from plex settings, it just plays the video without sound.
With previous versions of your firmware it worked fine so it must be something you changed in firmware 2.0.6.
Update: 2.09 has the same issue too. Back to 2.08 for me.Last edited by chrisarchon; 23 May 2015, 18:20.
There are currently 2962 users online. 0 members and 2962 guests.
