Kikat - Wasser Firmware for Beelink R89
Originally posted by mo123Yes, uses RKStagefright
No, have to use latest ROM for updated codec files.
Can manually extract them from a new ROM or download the binaries from Firefly SDK and copy it over to /system/lib
eg. libvpu.so, libstagefright.so, libffmeg.so, libbluray.so, librk_hevcdec.so, libmedia.so, librk_on2.so, librkffplayer.so
Also some HEVC improvements are in latest kernel, not system.
Thanks!
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
Also, to wasser, mo123, anyone else who knows, this system I am working on has mo123's v1.2 ROM (used for compatibility with tronsmart boot image and resource image so IR works) and I am installing SPMC 14beta2.
Anyway I was digging through the rc files trying to figure out how to init bluetooth on boot like the stock ROMs do. I added some lines to init.rc which are used on the firefly, haven't rebooted to check it yet.
While I was looking through the rc files I noticed in the init.rk30board.rc that the line 'insmod /system/lib/modules/vpu_service.ko' is commented out. Is this correct or should I remove the comment?
Another thing to mo123, you told me to use the lib files from firefly sdk but some of the libs at
Firefly-RK3288 / device / rockchip / common / vpu / lib /
in the hub were last updated last summer. Should I use the vpu ko from there as well? It is last updated 6/12/2014 (last summer).
Thanks!
Originally posted by sawbones999 View PostCan I use yours from the system image in your 1.4 rom or will the firefly sdk ones be most up to date? Also, is beta3 SPMC out yet?
Thanks!
-SB
Thanks!
Originally posted by sawbones999 View PostAlso I do not see a libvpu in the firefly git, only libomxvpu_enc.so and libomxvpu_dec.so
Thanks!
-SB
And here ? https://bitbucket.org/T-Firefly/fire...c.so?at=master#My players,
Ac Ryan Veolo 2
Ac Ryan Veolo 4K
Ac Ryan Playon!HD2
Ac Ryan Playon!HD3
Openhour fix stutter over smb/nfs
hi,
Openhour had fix the stuttering with their last firmware (1.0.10) : http://forum.openhourlab.com/showthread.php?tid=419
They wrote:
System:
- Fixed the playback random stuttering issue over SAMBA/NFS.
R.
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by Batfink32 View PostIt doesn't for me. Shame, I have a nice new 4k TV :-)
Because I read this http://www.freaktab.com/showthread.p...l=1#post229070 and it sounds it works, but maybe also a problem because of edid (I have a problem at 1080p, my TV can handle 24, 25, 30, 50 and 60 but the communication between box and TV only includes 50 and 60 so the box only allow 50 and 60 (you can see it at dmesg))...RK3288 Devices
Re: NEW - Wasser Firmware V2.0.3 for Beelink R89/Tronsmart R28
Maybe I've been sold a fake HDMI 2.0 cable? (I bought it from ****).
I looked in sys/devices/.... Hdmi modes and there's no option at all for 4k 60hz,only 4k 30. I'll have to do more digging around to see if I can find anything.
There are currently 3415 users online. 0 members and 3415 guests.
