Kikat - Wasser Firmware for Beelink R89
Originally posted by Henkdevries View PostTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by Henkdevries View PostI locked the cpu freq at 1800mhz when streaming a hd movie/show -> less stutter (still there a bit)
you can do this with the app "Tasker"
I hope there will be a proper fix soon though...
Just put the following in your init.d config file (or you can run it from the command line):
Code:/system/bin/iptables -F bw_INPUT /system/bin/iptables -F bw_OUTPUT
The culprit seems to be the following iptables rules:
Code:Chain bw_INPUT (1 references) pkts bytes target prot opt in out source destination 3162K 12G all -- * * 0.0.0.0/0 0.0.0.0/0 ! quota globalAlert: 2097152 bytes 7279K 57G all -- * * 0.0.0.0/0 0.0.0.0/0 owner socket exists Chain bw_OUTPUT (1 references) pkts bytes target prot opt in out source destination 1809K 113M all -- * * 0.0.0.0/0 0.0.0.0/0 ! quota globalAlert: 2097152 bytes 5369K 389M all -- * * 0.0.0.0/0 0.0.0.0/0 owner socket exists
So just delete those rules and voilà! Micro stutters gone...
Hope this works for you as well, let me know.
Cheers
Originally posted by vanzylst View PostGood news people, I've found a software-only fix/workaround to the micro stutter problem
CheersTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by amclean123 View PostWhat hardware are you having the problem with, Tronsmart R28 or Beelink R89? Also what movie type are you playing? Are you playing it over wifi or ethernet? I'm playing 40GB MKV files over ethernet on my local samba server and am not having problems with my R28.
i'm on spmc 14 beta 2 now, mostly streaming though the addon genesis and navi-X, h264 720p and 1080p files, over ethernet.
Haven't tested local files yet.
any thoughts are appreciated thanks.
Cheers
*edit* found it
I can confirm that this helps, my playback is now stutter free.
Excellent job sir, thank you!
Also i would like to add the following:
Do not use an advancedsettings.xml with network tweaks, i noticed that this is very sensitive. Stutters appear faster when using this. Do not stream to nand flash using cachemembuffersize 0. This also causes some stutters.
Keep it default.Last edited by Henkdevries; 04 January 2015, 12:45.
Cheers
i thank you so much for hard work.
my problems are solved. spmc works without stutters.
In the android config i set wlan0 off. eth0 is configured with manual ip.
"Fake Wifi Connection" lets playstore work over eth0. I'm not sure, if it is needed. Perhaps somebody can tell.
"Init.d" script lets the firewall work right after reboot. "External Keyboard helper" gives german keyboard layout [qwertz + äöü & Extrakeys like @;,:.#'+*?/|\ work with the right keypress].
If these functions would be implemented in the firmware - the media player would be perfect.
BIG thanks to all who helped me the last days!
PS: Who wants to buy an ethernet-usb-adapter?Last edited by ChiefWiggum; 04 January 2015, 16:26.Beelink R89 2/16GB Version PCB 3.0, Stock Firmware 111K4110_1219, SPMC 14.1
Input: Wireless Logitech K340 Keyboard & M505 Mouse, Output: Philips 42PFL7404H/12
NEW - Wasser Firmware V2.0.3 for Beelink R89/Tronsmart R28
"wifi faker" lets lets playstore work over eth0. I'm not shure, if it is needed. Perhaps somebody can tell.
Init.d script lets the firewall work right. External Keyboard helper gives german tastatur layout [qwertz + äöü & Extrakeys like @;,:.#'+*?/|\ work with the right keypress].
Originally posted by Elroy1 View PostIs this right? Or should i remove the first line?
[ATTACH]9627[/ATTACH]
As a check up you can add this line (not necessary)
Code:echo init.d is working >> /mnt/internal_sd/initdsupport.txt
If yes, you know the execute worked.
Awsome!!!
Cheers
But I like to know what does your workaround ??
Rob
Originally posted by hueb_s View PostWhat app do you use to fake wifi? I searched the play store but found nothing. Do you mean the xposed module?
Tested playstore and total commander.
PS: Nice, to talk english from German to GermanBeelink R89 2/16GB Version PCB 3.0, Stock Firmware 111K4110_1219, SPMC 14.1
It didn't remove micro freezez completely from my system but now these incidents are shorter and less frequent.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
There are currently 2562 users online. 0 members and 2562 guests.
