#!/system/bin/sh while [ ""`getprop dev.bootcomplete` != "1" ] ; do sleep 1; done ifconfig eth0 <[I]ip[/I]> <[I]netmask[/I]> route add default gw <[I]ip[/I]> dev eth0
Kikat - Wasser Firmware for Beelink R89
Stutter Fix by eth "mod"
Originally posted by vanzylst View Post
Originally posted by vanzylst View PostOriginally posted by vanzylst View Post
Code:RK3288 Devices
- Overview BOX (LINK !)
Originally posted by heiko123 View PostWhat did you mean with "something" ?
Gesendet von meinem SM-P905 mit Tapatalk 2Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Originally posted by wasser View Post
version 2.0.3
- add support for XBMC passthrough
- fix security issue
- fix permission issue for torrent stream tv
- update google apps
- add new wallpaper
- a lot of small stuffs which i don't remember
Firmware download: wasser-firmware-2.0.3
version 2.0.2
- fix codec issue which causes green pattern when playing video with stock player
- add ability to boot device in fullscreen mode (without statusbar, navigationvar), enable it by default
- add amazon instant video support
- update bootloader
- add ability to root or unroot device per recovery
- add ability to update FW per recovery
- fix a lot of stuffs which i don't remember
Info: Oman from Netxeon confirmed that the R89 PCB v2.0 doesn't has ability to controll the LED by the firmware, so it's not a bug in my firmware.
Download: root update
Download: unroot update
Firmware download: wasser-firmware-2.0.2
version 2.0.1
- fix DTS/Dolby audio issue
- false HDMI status to allow apps to run on HDMI output (e.g. SHOWTIME)
- fix DRM issue
Firmware download: wasser-firmware-2.0.1
version 2.0.0
- firmware now based on release-keys instead of test-keys to improve app compatibility
- multiuser support
- add support for no wakup on mouse movement, enable it by default
- fix red frame issue in chrome browser
- add hdm cec support
- 3d iso support
- update ffmpeg
- update bootloader v2.17.02
- fix contacts & calendar sync issue
- busybox up to date
- google apps up to date
- add chrome as default browser
- add hardware keyboard support and enable by default
- add lock screen, screensaver support
- google searchbar is disable by default
- enable tun and ip multicast in the kernel
- add dialog for reboot, sleep, reboot into bootloader and recovery mode
- init.d support
- ntfs, nfs, cifs, exfat filesystem support
- rooted
- add location setting
- 16gb in one partition
- add libmedia passthrough support
- built Wasser Kodi based on kodi 14 beta5 with DTS/DD5.1 passthrough support and native
- support for auto refresh rate switching (users need to manually activate this feature in Setting->Video->Playback)
- 7 x click on "ROM maker" in Setting->About device to enable Developer options menu,
- several another fixes which i don't remember
Overclocked kernels
Firmware download: cpu1800-ddr500-gpu533
Firmware download: cpu1800-ddr600-gpu600
Firmware download: cpu1800-ddr700-gpu600
Firmware download: cpu2000-ddr700-gpu600
Howto install OC update file:
- download the OC update files and copy them to external sdcard
- reboot device into recovery mode
- choose "apply update from external sdcard" from recovery menu
- select the oc update file
- reboot device after the update is done.
Thanks to Oman from Netxeon for his great support.
Firmware download: http://www.freak-tab.de/wasser/wasse...r89-rk3288.zip
Wasser-Kodi download: http://www.freak-tab.de/wasser/wasser-kodi-1.0.apk
Be aware: it is your own risk!
impossible to enter to recovery mode and usb burning tool dont work for me help plz
Originally posted by Oualid2013 View PostHi i have tronsmart s89h custom firmware wasser V1.0.3 but i dont find update app in setting and i want back to original FW
Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
[QUOTE=Oualid2013;264975]Originally posted by amclean123 View PostConnect the OTC USB to your PC. Open the case and short to pins with tweezers and then plug in the electric. Then click the Firmware button in Android Tool to pick your new firmware. Then click Upgrade
[ATTACH=CONFIG]9540[/ATTACH][ATTACH=CONFIG]9538[/ATTACH][/QUO
With Androidtool 2.3 say
loading firmware failed
ty for helpTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by manero View PostIt would be helpful if post a video from beginning to end of the process. Inexperienced thank
ty
I'll try tonight and see what I can come up with.
Here's why I had to use the motherboard reset instead of pushing the normal reset button on my Tronsmart R28. When I loaded the Beelink firmware on my Tronsmart R28 for some reason it didn't install the files needed to make my Tronsmart reset button work. Sometimes that just happens when you try using a firmware from another product. So I had to open the case and use the reset button on the motherboard. The reset on the motherboard is done by shorting together two pins, or in this case two holes where pins are normally located.
So unless you have a Beelink R89 I think you'll need to open your case, find your reset pins (or holes), short them together, and plug in the electric cable. Make sure your OTG USB cable is plugged in first.
I can tell you to NOT use pins/holes that are marked 5+ or 5-, those are for power! Unfortunately my pins were not marked. I had to do some Google searching and guessing.Last edited by amclean123; 31 December 2014, 23:55.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by Oualid2013 View PostBut dont work for me i have tronsmart s89h with custom FW wasser V1.0.3 i dont can back to original FW but now no recovery mode no loader can do that and update app is not in setting
tyTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Tronsmart R28 Remote control
Wasser could you please add the functionality for the Tronsmart R28 remote control back into this firmware build or could someone point me in the right direction on how to do it? I've spent a few hours on Google and can't seem to find the location where remote control files are held in the file system and how to get them loaded.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
There are currently 2085 users online. 1 members and 2084 guests.
