I too would like to try this out. But, I'm unable to complete the necessary unmount or e2fsck commands on any of the found ext4 volumes. They are all in use. Is there a way to boot just to a console to accomplish this?
Kikat - Wasser Firmware for Beelink R89
BTW. Of all the ROMs I have tested mo123 dual boot (only installed android) is the only one where 1080p YouTube app works. I know wasser will turn the bee link 111k4 into a nice ROM.The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
Originally posted by crazymark View Post
Use AndroidTool_Release_v2.3RK3288 Devices
- Overview BOX (LINK !)
Originally posted by wasser View Postcan someone please confirm "disable journal" fixes micro stutters?
i can add this fix in next firmware release if it really fixes micro stutters
Wasser
However, my experience is that removing the journal does improve things quite a bit, but it would be good if someone else can confirm as well.
I did manage to remove the journal on all the mounted partitions. I found a different e2fsck which would allow me to force the fsck on all the mounted partitions, whereafter I could run tune2fs -O ^has_journal to remove the journal.
This e2fsck worked for me (I assume it's part of Rom Manager which one can install from the Play Store):
-rwxr-xr-x 1 app_65 app_65 428664 Dec 25 20:01 /data/data/com.koushikdutta.rommanager/files/e2fsck
This one didn't:
-rwxr-x--- 1 system system 289448 Jan 1 1970 /sbin/e2fsck
Originally posted by Gormar View Post@ICU. Hold your horses for a moment. I've just found something strange. There are writes to disk quite often because jbd2 process is updating EXT4 jurnal and sometime kworker is hiking along repeatedly every 5-6 seconds. These operations doesn't generate too much data because only 4kB (8 sectors) is written for each but if we have 30-40 similar events in one second and factor poor IO performance of this device eMMC then it isn't funny.
Code:<7>[12447.539933] jbd2/mmcblk0p13(128): WRITE block 12891048 on mmcblk0p13 (8 sectors) ... <7>[12448.654973] kworker/u8:3(13334): WRITE block 22871632 on mmcblk0p13 (72 sectors)
echo "1" > /proc/sys/vm/block_dump
Disable:
echo "0" > /proc/sys/vm/block_dump
Tomorow I will check if my old BOX have similar behavior. Maybe this device is salvageable
Code:<7>[ 1989.823437] NetworkStats(530): WRITE block 4264 on mmcblk0p12 (8 sectors) <7>[ 1990.541758] NetworkStats(530): WRITE block 1772776 on mmcblk0p12 (16 sectors) <7>[ 1990.543191] NetworkStats(530): WRITE block 3944 on mmcblk0p12 (8 sectors) <7>[ 1990.556987] NetworkStats(530): WRITE block 1772792 on mmcblk0p12 (8 sectors) <7>[ 1990.558007] NetworkStats(530): WRITE block 3872 on mmcblk0p12 (8 sectors) <7>[ 1991.179627] NetworkStats(530): WRITE block 1772800 on mmcblk0p12 (16 sectors) <7>[ 1991.180402] NetworkStats(530): WRITE block 4264 on mmcblk0p12 (8 sectors) <7>[ 1991.194462] NetworkStats(530): WRITE block 1772816 on mmcblk0p12 (8 sectors) <7>[ 1991.195243] NetworkStats(530): WRITE block 3944 on mmcblk0p12 (8 sectors) <7>[ 1991.290620] kworker/u8:1(6387): WRITE block 1088 on mmcblk0p12 (8 sectors) <7>[ 1991.290652] kworker/u8:1(6387): WRITE block 1160 on mmcblk0p12 (8 sectors) <7>[ 1991.290664] kworker/u8:1(6387): WRITE block 1416 on mmcblk0p12 (8 sectors) <7>[ 1991.290674] kworker/u8:1(6387): WRITE block 3872 on mmcblk0p12 (8 sectors) <7>[ 1991.290688] kworker/u8:1(6387): WRITE block 67968 on mmcblk0p12 (8 sectors) <7>[ 1991.290706] kworker/u8:1(6387): WRITE block 8 on mmcblk0p12 (8 sectors) <7>[ 1991.290716] kworker/u8:1(6387): WRITE block 1080 on mmcblk0p12 (8 sectors)
Originally posted by Gilgamesh View Postguys, these micro stutters, what is the cause of them? the not so "speedy" eMMC? or CPU?
It looks to me that the slow eMMC coupled with background processes doing regular writes is a contributor to the problem, but there are probably other causes as well.
ok will see if the HPH NT-V6 4GB/32GB box I ordered will behave the same as they use a much faster Samsung eMMC, write speed about 20MB/s, read 55MB/s compared to R28 Meta 10/35MB/s... but the Samsung eMMc is supposed to be even faster than that when looking at the specs.. but will see.
Tapatalked from my GALAXY S5
Re: NEW - Wasser Firmware V2.0.3 for Beelink R89/Tronsmart R28
Originally posted by crazymark View Postthanks for your answer!!
Using Androidtool 2.3, tab "Upgrade frmware" and select "firmare" --> "wasser firmware".img and click upgrade?
Sent from my One using Tapatalk
antutu video tester feedback
I ran Antutu video tester and here are the results of Wasser V2.0.3
Some audio problems occured vs. 110k4 roms had no indicated playback issue with this test.
I am still looking for a solution to solve Phillips TVs HDMI HDCP handshake issue: resulting in green/blue screens randomly for a short time. Any suggestion? 110k4 roms dont have this issue.Beelink R89 PCB V3.0
Running on Finless V1.2 at the moment
Originally posted by vanzylst View PostThis e2fsck worked for me (I assume it's part of Rom Manager which one can install from the Play Store):
NOTE: Once you install "Rom Manager" you need to launch it so that the app can update and pull down the e2fsck file.
The only mount points that I had to do this to were the following:/dev/block/mmcblk0p8
/dev/block/mmcblk0p10
/dev/block/mmcblk0p11
/dev/block/mmcblk0p12
I ran the following commands on each one:
tune2fs -l /dev/block/mmcblk0p8("| grep features" didn't work for me so I omitted it and just scrolled up)/data/data/com.koushikdutta.rommanager/files/e2fsck -f /dev/block/mmcblk0p8
This will let you see if the line Filesystem features: has_journal exists
(answer Y to all)tune2fs -O ^has_journal /dev/block/mmcblk08
(this is a capital "O"!)
This command removes journaling.
Do this for all four and reboot.
Now to test for micro stutters...
*UPDATE*
stutters still exist. Especially bad with 24p content (SD or HD).
The only way I was able to solve this was to turn OFF "adjust display refresh rate to match video" and turn ON "Sync playback to display" from within XMBC System -> Video -> Playback. Oh well..Last edited by sillykeith; 28 December 2014, 00:28.
There are currently 2108 users online. 2 members and 2106 guests.
