Kikat - Wasser Firmware for Beelink R89
Portrait mode
Thank you Wasser for your 2.0.2 Firmware for the BeeLink R89. It is very clean and fast. Are there any plans to add the Screen Rotate feature in the Developers options in settings like you have in your MiniX X7 Firmware?
I did install a rotation app from the Play store, but it looks like something still needs to be enabled in the firmware first before it will flip.
Originally posted by georget View PostThank you Wasser for your 2.0.2 Firmware for the BeeLink R89. It is very clean and fast. Are there any plans to add the Screen Rotate feature in the Developers options in settings like you have in your MiniX X7 Firmware?
Isn't a TV Box supposed to show landscape on a HDTV?
Or are you running old apps that require portrait to work?
Curious...
Hey Wasser, I flashed your rom and installed you Wasser-kodi app, but can't get it to work.
I received the beelink r89 2gb/16gb 2 days ago, flashed your rom like described in that other page. Games are running fine but can't get kodi. Any idea how I could fix this? Reflashing wasser 2.0.2? Trying another rom?
Thanks for the great rom. If I can have this Kodi issue fixe it'll be great!
Originally posted by Laethageal View PostHey Wasser, I flashed your rom and installed you Wasser-kodi app, but can't get it to work.
TRY SPMC http://spmc.semperpax.com/ . I stable using SPMC
Hello.
With 3188 box, with your custom rom Wasser 1.04 there is no problem in playing from torrents (xbmctorrent to be precise). Is it possible to do the same for the 3288 boxes? Because currently the playing stops after some 15-30 minutes with a crash of the above script. This happens only in Android and not other platforms, so the script works and we can ignore it. I have noticed that the time depends on movie quality and therefore some cache on disk. When this reaches 2GB it crashes and this happens in all roms, stock roms of boxes included. Only with your custom rom this does not happen, all works properly. So, is it possible to determine what is different in Wasser 1.04 on 3188, with current Wasser 2.0.2 on 3288 (like belink).
Thank you.
There are currently 2683 users online. 0 members and 2683 guests.
